both arduinos have the same code.
this is the example "ArtNetNeoPixelRGBW" from artnet library:
This example will receive multiple universes via Artnet and control a strip of sk6812RGBW leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
// Neopixel settings
const int numLeds = 352; // change for your setup
const int channelsPerLed = 4;
const int numberOfChannels = numLeds * channelsPerLed; // Total number of channels you want to receive (1 led = 4 channels)
const byte dataPin = 2;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRBW + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {192, 168, 1, 65};
byte mac[] = {0x04, 0xE9, 0xE5, 0x00, 0x69,0xEC};
//Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data, IPAddress remoteIP)
sendFrame = 1;
// set brightness of the whole strip
if (universe == 15)
leds.setBrightness(data[0]);
leds.show();
// Store which universe has got in
if ((universe - startUniverse) < maxUniverses)
universesReceived[universe - startUniverse] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived[i] == 0)
//Serial.println("Broke");
sendFrame = 0;
// read universe and put into the right part of the display buffer
for (int i = 0; i < length / channelsPerLed; i++)
int led = i + (universe - startUniverse) * (previousDataLength / channelsPerLed);
if (led < numLeds) {
if (channelsPerLed == 4)
leds.setPixelColor(led, data[i * channelsPerLed], data[i * channelsPerLed + 1], data[i * channelsPerLed + 2], data[i * channelsPerLed + 3]);
if (channelsPerLed == 3)
leds.setPixelColor(led, data[i * channelsPerLed], data[i * channelsPerLed + 1], data[i * channelsPerLed + 2]);
previousDataLength = length;
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < numLeds ; i++)
leds.setPixelColor(i, 127, 0, 0, 0);
leds.show();
leds.setPixelColor(i, 0, 127, 0, 0);
leds.show();
leds.setPixelColor(i, 0, 0, 127, 0);
leds.show();
leds.setPixelColor(i, 0, 0, 0, 127);
leds.show();
leds.setPixelColor(i, 0, 0, 0, 0);
leds.show();
