Your code:
#include <MsTimer2.h> //Timer interrupt function library
int pbIn = 0; // Define interrupt 0 that is digital pin 2
int pbIn2 = 1;
int ledOut = 13;
int ledOut2 = 12; // Define the indicator LED pin digital pin 13
int number = 0; //Interrupt times
int number2 = 0;
volatile int state = LOW; // Defines the indicator LED state, the default is not bright
volatile int state2 = LOW;
void stateChange2() { //Interrupt service function
number2++; //Interrupted once, the number +1
void Handle() //Timer service function
if (number > 1) //If in the set of the interrupt time the number more than 1 times, then means have detect moving objects,This value can be adjusted according to the actual situation, which is equivalent to adjust the threshold of detection speed of moving objects.
delay (1000);
state = HIGH;
digitalWrite(ledOut, state); //light led
number = 0; //Cleare the number, so that it does not affect the next trigger
number = 0; //If in the setting of the interrupt time, the number of the interrupt is not reached the threshold value, it is not detected the moving objects, Cleare the number.
void Handle2() //Timer service function
if (number2 > 1) //If in the set of the interrupt time the number more than 1 times, then means have detect moving objects,This value can be adjusted according to the actual situation, which is equivalent to adjust the threshold of detection speed of moving objects.
state2 = HIGH;
digitalWrite(ledOut2, state2); //light led
number2 = 0; //Cleare the number, so that it does not affect the next trigger
number2 = 0; //If in the setting of the interrupt time, the number of the interrupt is not reached the threshold value, it is not detected the moving objects, Cleare the number.
void stateChange() { //Interrupt service function
delay(1);
(number = number + 1);
if (number <= 1) {
number == 0;//Interrupted once, the number +1
pinMode(ledOut, OUTPUT);//
pinMode(ledOut2, OUTPUT);
attachInterrupt(pbIn, stateChange, FALLING); // Set the interrupt function, interrupt pin is digital pin D2, interrupt service function is stateChange (), when the D2 power change from high to low , the trigger interrupt.
attachInterrupt(pbIn2, stateChange2, FALLING);
MsTimer2::set(1000, Handle); // Set the timer interrupt function, running once Handle() function per 1000ms
MsTimer2::set(1000, Handle2);
MsTimer2::start();//Start timer interrupt function
Serial.print("sensoruno");
Serial.println(number);
Serial.print("sensordos");
Serial.println(number2);// Printing the number of times of interruption, which is convenient for debugging.
Serial.println("-");
delay(100);
if (state == HIGH) //When a moving object is detected, the ledout is automatically closed after the light 2S, the next trigger can be carried out, and No need to reset. Convenient debugging.
delay(100);
state = LOW;
if (state2 == HIGH) //When a moving object is detected, the ledout is automatically closed after the light 2S, the next trigger can be carried out, and No need to reset. Convenient debugging.
delay(100);
state2 = LOW;
digitalWrite(ledOut2, state2);//turn off led
All variables used inside an ISR and the main code have to be declared volatile.
All multi byte variable have to be accessed in an atomic block (with disabled interrupts) from the main code.
delay does not work inside an ISR, millis() needs interrupts to tick.
I would use digitalPinToInterrupt instead of using the raw interrupt numbers.
Have a look at Gammon Forum : Electronics : Microprocessors : Interrupts.
The variable names number and number2 are abysmal IMHO.
