Hello,
I have trouble with "simple" part of my project.
I am using two boards in my project - ESP8266 and ESP 01.
ESP8266 is doing lot of stuff - collecting information of sensors (sending them to Google spreadsheet), evaluates the values and controls the relays.
My idea was to add HW watchdog - each controller will control another one
So if ESP8266 gets into an error state (its happening when WiFi is lost right during connecting - calling HTTPS GET) ESP 01 will trigger a restart.
And vice versa it will work the same - if ESP 01 is not responding - ESP8266 will trigger a restart.
Both devices are rebooting if there is LOW impulse on the RST pin.
The logic level on the WATCHDOG pin changes every 1000 ms.
The logic level is controlled by the pin PIN_INPUT.
At each change noted on the pin PIN_INPUT, a countdown is started - if the countdown reaches 60000 ms, a restart is triggered - with a LOW value on the pin PIN_OUTPUT.
Similar code runs on both two boards.
Unfortunately, I don't know why, but the resets happen even if there is no problem on the boards ... quite rarely (randomly), but it happens.
Does anyone have any idea what could be causing the random reset?
In theory it should work like this without problems..
#define PIN_INPUT 1
#define WATCHDOG 2
#define PIN_OUTPUT 3
int control= 0;
int last_control = 0;
bool watchdog = false;
//promenne pro casovani milis()
unsigned long previousMillis = 0;
const long interval = 500; // frequency of logic level check - 500 ms
unsigned long previousMillisCheck = 0;
unsigned long previousMillisWD = 0;
const long intervalWD = 1000; // timer for watchdog - every 1s changes logical level
const long timeWithoutResponse = 60000; // maximum allowable time between state change checks
pinMode(PIN_INPUT, INPUT);
pinMode(PIN_OUTPUT, OUTPUT);
pinMode(WATCHDOG, OUTPUT);
digitalWrite(PIN_OUTPUT, HIGH);
// begin ********* HW WATCHDOG - CONTROL STATE OF ESP8266 *********
if (currentMillis - previousMillis >= interval) {
control= digitalRead(PIN_INPUT);
if (control != last_control){
previousMillisCheck = currentMillis;
if (currentMillis - previousMillisCheck >= timeWithoutResponse){
digitalWrite(PIN_OUTPUT, LOW);
Serial.print("restarting......");
last_control = control;
digitalWrite(VYSTUP, HIGH);
// end ********* HW WATCHDOG - CONTROL STATE OF ESP8266 *********
// begin ********* HW WATCHDOG INTERNAL CYCLE *********
if (currentMillis - previousMillisWD >= intervalWD)
previousMillisWD = currentMillis;
Serial.print("WATCHDOG: ");
if (watchdog == false) {
digitalWrite(WATCHDOG, LOW);
Serial.println(watchdog);
digitalWrite(WATCHDOG, HIGH);
watchdog = !watchdog;
// end ********* HW WATCHDOG INTERNI CYKLUS *********`
