Hello!
I was working on a project with a ESP32 Lolin32 lite where I'm using a phone connected to the esp by bt to send some data and then based on what the ESP32 received it will send other data to another BT phone. I couldn't find many info online so I was wondering if it's even possible.
Thank you
After hours of research I found this code here:
#include <BluetoothSerial.h>
BluetoothSerial SerialBT;
char receivedChars[256]; // Array to store received data
boolean newData = false; // Flag to indicate new data received
SerialBT.begin("ESP32_BT"); // Set Bluetooth name
Serial.println("Waiting for Bluetooth connection...");
if (SerialBT.available()) {
char c = SerialBT.read();
if (c == '\n') { // End of transmission character
receivedChars[SerialBT.available()] = '\0'; // Add null terminator
newData = true; // Set flag to indicate new data received
// Append character to receivedChars array
strncat(receivedChars, &c, 1);
if (newData) {
Serial.println("Received data: " + String(receivedChars));
// Process the received data if needed
// Send the received data to another phone via Bluetooth
sendBluetoothData(receivedChars);
// Reset the receivedChars array and flag for new data
memset(receivedChars, 0, sizeof(receivedChars));
newData = false;
void sendBluetoothData(const char* data) {
// Connect to the other phone via Bluetooth
BluetoothSerial bt;
bt.begin("OTHER_PHONE_BT"); // Set Bluetooth name of the other phone
// Send the data to the other phone
bt.println(data);
// Disconnect from the other phone
bt.end();
But I noticed that at the end it disconnects from the second BT device. Is it a problem if I let it connected? Because this is a moving robot and the second device will be on it so that when I receive the data from the esp, using a text to speech tool I can hear the answer, so if I can't let it connected I'll have to take the tablet, reconnect it again and put it back on the robot which is not the best thing in the world
