2 buttons, 3 leds and a 60 second delay
Hellow.
I'm trying to make a simple system which is simple on paper but won't work with the code. I'm a noob just so you know.
The situation is like this.
I have 2 switches
One of them is ON/OFF and the other is a push button.
1 led RED
1 led GREEN
1 led BLUE
The ideea is this.
Button 1 (on/off)
When it's off I want it to read the pushbutton.
When the pushbutton is pushed i want it to turn on the RED led, wait 60 seconds then turn the RED led off and turn on the GREEN one. The pushbutton will be pushed the whole time and i want the GREEN led to stay on until the pushbutton is released.
so that's it when it's on OFF mode:
  1. All leds OFF
  2. Push button is pushed
  3. Red led is ON
  4. count 60 seconds
  5. RED led off and GREEN led is ON.
When the push button is released ALL leds should be OFF and can repeat the sequence if i push the button again.
ON/OFF switch is ON.
When the switch is in ON position i want it to read the push button. ALL LEDS ARE OFF. If that pushbutton is pushed i want it to turn on the BLUE led, wait 60 seconds, then turn on the red led and trigger 5 volts on a pin for 1 second. After the pushbutton is released ALL LEDS ARE OFF and i can repeat the sequence.
so, in ON mode it should be like this:
  1. All Leds off
  2. Push button is pushed and kept that way
  3. BLUE LED is ON
  4. WAIT 60 seconds
  5. BLUE LED IS OFF
  6. RED LED IS ON
  7. Give me 5 volts on one pin.
Can this be done only with an arduino UNO and no other hardware timers and so on?
The uno can do that using its internal millis timer so yes it can be done
have you got any code written yet?
The code I wrote is useless....
I've only declared the pins and tryed to use the delay function... but obviously i ran into some problems. The on/off push button delay acts both ways. On pressing and releasing...
And sometimes it won't turn off the other led.
I've read something about milis but... as I sayed I am a noob.
I have this arduino for about 3 days... so you can't expect much from me. but I want to do this project this week-end if it's possible... i hope :slight_smile:
Consider this page here, if you haven't read it yet already.
This is the chunk that deals with using millis() as a timer and when a time is reached,
an action is performed.
Attempt at copying the example code from that page and modifying it to suit your needs. If need be copying it multiple times as your program grows.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
In this case
is used to do the check and update at a set interval. You would likely want to run your timers once.
and
      ledState = HIGH;
      ledState = LOW;
is the action. Replaced with whatever action you might want.
Give your attempt at integrating your pseudo code into actual code and if you cannot get it to compile or run as you like, help can be given. At this time you would post your entire code.
I'll try it. I'll post my code but you will only see how retarded I am and nothing more. I'm still in the phase of writing without the on/off switch and I'm failing.
I'll post the fail after i try the milis :slight_smile:
Thank you
bad code will get you 10 times more help than no code. Plus it helps us understand what you are thinking.
read how to post code first (top of forum) and you will get even more help
The demo Several Things at a Time is an extended example of BWoD.
...R
So... this is my code (so far)
I'm still using the delay because i can't manage to turn off led1 when led 2 is ON.
const int buttonPin = 2;
const int ledPin = 13;
const int led2Pin = 12;
int buttonState = 0;
int ledState = LOW;
int led2State = LOW;
  pinMode(ledPin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  buttonState = digitalRead(buttonPin);
  ledState = digitalRead(ledPin);
  led2State = digitalRead(led2Pin);
  if (buttonState == HIGH) {
      led2State = LOW;
      ledState = HIGH;
      digitalWrite(ledPin, HIGH);
      delay(200);
      digitalWrite(led2Pin, HIGH);
    else {
    digitalWrite(led2Pin, LOW);
    digitalWrite(ledPin, LOW);
}[/code}
added notes in the code
I think you started with a bad example code
//int ledState = LOW;//junk no need for this
//int led2State = LOW;//junk
unsigned long interval = 200; //200ms
unsigned long previousMillis = 0;
  pinMode(buttonPin, INPUT);//look at INPUT_PULLUP
  unsigned long currentMillis = millis();//millis is the internal timer
  // ledState = digitalRead(ledPin);//junk its a output it will stay where its set
  //  led2State = digitalRead(led2Pin);//junk
  if (buttonState == HIGH) {//hope you have a pull resistor
    //if not use INPUT_PULLUP and check for LOW
    //   led2State = LOW;//junk who cares what state the pin is in
    //   ledState = HIGH;//junk
    //rest of the code looks fine
      //this will happen 200ms after button is pushed
  else {
    previousMillis = currentMillis; //if button not pressed keep updating time stamp
So far it works with a little problem.
The red led (first) it's not shutting down completely. It only dimms about 70%. Is that a circuit problem or something in the code? I'm working on a breadbord.
Here is the code now.
  pinMode(buttonPin, INPUT_PULLUP);
  int sensorVal = digitalRead(2);
  Serial.println(sensorVal);
 if (sensorVal == HIGH)  {
  else {
I wonder if this ELSE clause should have any digitalWrite()s in it
    else {
It would be much easier to follow your code with meaningful variable names - for example redLedPin
...R
If I don't use digitalwrite after the ELSE the green led will be ON at the release of the button.
I have changed the code names but i taught it is easyer without the long names at the beginning.
I have also added a buzzer when the red led turns off but it beeps continuously. I'm searching for a function to stop it after one beep. I'm not posting the code yet... i'll post it when i'm giving up :slight_smile:
Have you got pullup or pulldown resistors on your input pins?
Tom.... :slight_smile:
For the button i have this setup:
You should include all your components in your schematic. A sketch on the back of an envelope is vastly preferable to one of those Fritzing diagrams.
It's not ready. The picture above was from the button example.
So... regarding the buzzer... I simply give up. I cleaned all my attempts to end the buzzer at one beep but i failed. Also searched on google and nobody wats to stop the beep after one count...
What do you guys reccomend?
const int redPin = 13;
const int greenPin = 12;
const int buzzerPin = 11;
const int bluePin = 10;
const int switchPin = 9;
int switchState = 0;
unsigned long interval = 2000; //200ms     60000/ 1min
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(switchPin, INPUT_PULLUP);
  switchState = digitalRead(switchPin);
    digitalWrite(redPin, HIGH);
      digitalWrite(redPin, LOW);
      digitalWrite(greenPin, HIGH);
      for (int i=0; i<300; i++) {  // generate a 1KHz tone for 1/2 second
      digitalWrite(buzzerPin, HIGH);
      delayMicroseconds(100);
      digitalWrite(buzzerPin, LOW);
      delayMicroseconds(300);
      digitalWrite(bluePin, HIGH);
  else {
    digitalWrite(greenPin, LOW);
    digitalWrite(bluePin, LOW);
please stop digitally reading the same button 2 different ways and if you change code on a example change the text to show you know what affect the change is making
example code untested but its a correction of your code
byte   buzzerRequest = 0;
byte onetime = 0;
unsigned long interval = 2000; //2 seconds
unsigned long interval2 = 500;
unsigned long previousMillis2 = 0;
  byte button = digitalRead(buttonPin);//push button
  byte m_switch = digitalRead(switchPin);//switch maintained
  if (button == LOW) { //button is pressed as this is a input pullup
      if (onetime == 0) {//only do this once unless button is released
        buzzerRequest = 1;//tell buzzer we require noise
        previousMillis2 = currentMillis;//set the time stamp to turn buzzer off
        onetime = 1;//block this if so it only goes onetime
  else {
    buzzerRequest = 0;
    onetime = 0;
  if (currentMillis - previousMillis2 >= interval2) {
    buzzerRequest = 0;
  if (buzzerRequest == 1) {
The buzzer count from your code works. However my LED's go nuts.
I'll post the final code when I'm done. I've added the second switch and second set of commands.
So... i have the updated but not finished code.
Without the acoustic and the trigger everything works as I intended. I have also made notes in the code and added a 3'rd time interval (for the trigger).
const int bluePin    = 11;
const int buzzerPin  = 10;
const int triggerPin = 8;
byte onetime    = 0;
unsigned long interval2 = 800; // Used for BUZZER
unsigned long interval3 = 100; // Used for TRIGGER
unsigned long previousMillis3 = 0;
//_________________________________________________OK
  pinMode(triggerPin, OUTPUT);
  int switchVal = digitalRead(9);
  Serial.println(switchVal);
  unsigned long currentMillis2 = millis();
  unsigned long currentMillis3 = millis();
// Switch ON
 if (switchVal == HIGH) {
      for (int i=0; i<300; i++) {  // BUZZER needs to beep only once
      digitalWrite(triggerPin, HIGH); // trigger must be 1 second long - ONLY
  else {
// System shutdown when button is released! NEEDED because it works with the hardware. Otherwise LED's go crazy.
    digitalWrite(triggerPin, LOW);
// System shutdown! NEEDED.
// SWITCH OFF!
  else {
Format your code properly (use the AutoFormat tool) so you can easily see which IFs and ELSEs etc belong together.
My suggestion in Reply #10 was based on the possibility that code was in the wrong place.
And please describe what the latest code (in Reply #18) actually does and what it should do. It is too difficult to infer that accurately from the sequence of Posts.
...R
