2 buttons executing different code
Hi, I'm trying to incorporate two buttons into my code that make a motor move forward and reverse respectively. Here is how I have written it
  buttonState1 = digitalRead(buttonPin1);
  if ((millis() - lastDebounceTime1)>debounceDelay)
  //only if time since last button press > time buffer will code run
  if (buttonState1 == HIGH)
    if (letsgo1 == false)
    letsgo1=true;
    starttime = millis();
    dsa_point = 0;
    digitalWrite(led_ProgRun, HIGH);
    Serial.write(254);
    Serial.write(1);//clears LCD
    Serial.print("Running Sequence...");
    lastDebounceTime1 = millis();
    digitalWrite(SLEEP1, HIGH);
    digitalWrite(SLEEP2, HIGH);
    digitalWrite(SLEEP3, HIGH);
    else //letsgo == true
    letsgo1 = false;
    digitalWrite(led_ProgRun, LOW);
    Serial.write(254);
    Serial.print("Sequence Aborted.");
    digitalWrite(SLEEP1, LOW);
    digitalWrite(SLEEP2, LOW);
    digitalWrite(SLEEP3, LOW);
  if (letsgo1==true)
    currenttime = millis() - starttime;
    if (dosomethingat[dsa_point][0] <= currenttime)
     switch (dosomethingat[dsa_point][1])
      case 1: //when switch variable = 1
      if (dosomethingat[dsa_point][2]==1)
        stepper1.setMaxSpeed(dosomethingat[dsa_point][3]);
        stepper1.move(dosomethingat[dsa_point][4]);
      case 2:
        stepper2.setMaxSpeed(dosomethingat[dsa_point][3]);
        stepper2.move(dosomethingat[dsa_point][4]);
      case 0: //
      Serial.write(254);
      Serial.print("Sequence complete.");
    dsa_point = dsa_point +1;
buttonState2 = digitalRead(buttonPin2);
  if ((millis() - lastDebounceTime2)>debounceDelay)
    if (buttonState2 == HIGH)
      if (letsgo2 == false)
        letsgo1 = false;
        letsgo2 = true;
        Serial.write(254);
        Serial.print("Withdrawing Syringes...");
        lastDebounceTime2 = millis();
        stepper1.setMaxSpeed(1000);
        stepper1.move(-20000);
        stepper2.setMaxSpeed(1000);
        stepper2.move(-20000);
  else //letsgo2 == true
    letsgo2 = false;
    Serial.write(254);
    Serial.print("Load Syringe");
stepper1.run();
stepper2.run();
However this does not work and the motor moves forward for about half a second when I press the first button. Any suggestions?
Your {curly braces} are incomplete.
Switch.. case will not work as you think it is.
Fix that and try again.
I'm not sure I follow, that switch case worked fine in a different code and was simply copied and the second button was added
It does not seem like the second if will run since false was set just previous.
    letsgo1 = false;
    Serial.write(254);
  if (letsgo1==true) // will this ever be true at this point if you set it false every time above???
I was wrong.
Looked at a working sketch of mine where every case was followed by a {} but the reference pages do not show those.
So the {} are not necessary in this case, so sorry.
@C2, that part of the code works fine as I've tried it without the second button. However once the second button is added it doesn't work..
What do your serial prints tell you is happening? Why don't you have any?
Why don't you use Tools + Auto Format to fix that horrid mess?
