2 channel filter
Hi
Why on serial plotter both Af and Bf are the same ?
#include <filters.h>
const float cutoff_freq   = 5.0;  //Cutoff frequency in Hz
const float sampling_time = 0.005; //Sampling time in seconds.
IIR::ORDER  order  = IIR::ORDER::OD3; // Order (OD1 to OD4)
// Low-pass filter
Filter f(cutoff_freq, sampling_time, order);
  int valueA = analogRead(PA5);//+++++++++++++++++++++++++++++++++++++++++
  float filteredvalA = f.filterIn(valueA);
  int valueB = analogRead(PA7);  //+++++++++++++++++++++++++++++++++++++++
  float filteredvalB = f.filterIn(valueB);
  Serial.print("A = ");
  //Serial.print(valueA, DEC);
  Serial.print("  Af = ");
  Serial.print(filteredvalA, 4);
  Serial.print("  B =  ");
 // Serial.print(valueB , DEC);
  Serial.print("  Bf =  ");
  Serial.println(filteredvalB , 4);
  delay(5); // Loop time will approx. match the sampling time.
Perhaps because valueA and valueB are the same?
Did you run the examples coming with the library?
Try two Filter fA, fB for separate signals A and B.
Thanks
Problem solved
For the records: How that?
const float cutoff_freqA   = 5.0;  //Cutoff frequency in Hz
const float sampling_timeA = 0.005; //Sampling time in seconds.
IIR::ORDER  orderA  = IIR::ORDER::OD3; // Order (OD1 to OD4)
const float cutoff_freqB   = 5.0;  //Cutoff frequency in Hz
const float sampling_timeB = 0.005; //Sampling time in seconds.
IIR::ORDER  orderB  = IIR::ORDER::OD3; // Order (OD1 to OD4)
// Low-pass filter
Filter fA(cutoff_freqA, sampling_timeA, orderA);
Filter fB(cutoff_freqB, sampling_timeB, orderB);
  float filteredvalA = fA.filterIn(valueA);
  float filteredvalB = fB.filterIn(valueB);
  // Serial.print("A = ");
  // Serial.print(valueA, DEC);
  //  Serial.print("  B =  ");
Please post a link to the filter library you are using.
https://github.com/MartinBloedorn/libFilter/blob/master/filters.h
Thanks! Documentation is pretty weak but if it does what you want, fine.
