Thank you sherzaad for your help.
I want to test your input.
I will repond you of the test.
Regards
Reka6
Assuming you are using a UNO, pin 4 does NOT support analogWrite but on the other hand pin 3 does. so I should suggest you sway the connections over and change your code to something like this:
OP's code (amended):
(Compiles, NOT tested!)
int Pot1 = A1;
int Pot2 = A0;
int val;
int val2;
//put your setup code here, to run once:
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(A1, INPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(A0, INPUT);
int val = analogRead(A1);
if (val > 1 && val < 490) {
val = map (val, 1, 490, 255, 0);
analogWrite (5, 0);
analogWrite (6, val);
else if (val > 530 && val < 1023) {
val = map (val, 530, 1023, 0, 255);
analogWrite (6, 0);
analogWrite (5, val);
else if (val > 491 && val < 529) {
val = map (val, 491, 529, 0, 0);
analogWrite (6, 0);
analogWrite (5, 0);
int val2 = analogRead(A0);
if (val2 > 1 && val2 < 490) {
val2 = map (val2, 1, 490, 255, 0);
analogWrite (4, 0);
analogWrite (3, val2);
else if (val2 > 530 && val2 < 1023) {
val2 = map (val2, 530, 1023, 0, 255);
analogWrite (4, 0);
else if (val2 > 491 && val2 < 529) {
val2 = map (val2, 491, 529, 0, 0);
analogWrite (4, 0);
analogWrite (3, 0);
Serial.println(val);
Serial.println(val2);
hope that helps....
sherzaad:
int Pot1 = A1;
int Pot2 = A0;
int val;
int val2;
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(A1, INPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(A0, INPUT);
analogWrite (5, 0);
analogWrite (6, 0);
analogWrite (6, 0);
analogWrite (5, 0);
analogWrite (4, 0);
analogWrite (4, 0);
analogWrite (4, 0);
analogWrite (3, 0);
hope that helps....
