I am trying to save data in 2 dimension array by using this commands:
char IRcode2[i][j];
IRcode2[1][3] = '1';
IRcode2[0][3] = '2';
IRcode2[2][3] = '4';
for (int i= 3 ; i <= 3; i++ ) {
for (int j= 0 ; j < 3; j++ ) {
Serial.print("j = ");
Serial.print(j);
Serial.print(" , i = ");
Serial.println(i);
Serial.println(IRcode2[j][i]);};
but in serial print I got these:
j = 0 , i = 3
4
j = 1 , i = 3
4
j = 2 , i = 3
4
why??
I have no idea... I need your help
Thanks
What were i and j at the first line of your snippet when this line was run:
char IRcode2[i][j];
try:
char IRcode2[3][4];
Thank you , I changed it and it works!
So I have to declare the size of array at first!!!!!
parmares:
You must always create the array before you use it. Your i and j were set in the piece of code you didn't include, so I have no idea how big your array actually was. Basically, you were writing to random memory, which causes all sorts of problems.
you right!
I didn't mention it. I just declared i and j like this:
int i, j;
thank you again, now it works well
remove those declarations of i and j, since they are only used in your for loops, where you also declare them. This is a different i and j and would cause confusion. It will stop these sort of problems occurring, as the compiler will warn you.
