2 distance sensors
Hi everybody.
I am working on my robot, and i want to add a ultrasonic distance sensor( a HC-SR04 ) i already have one installed to avoid objects.
Now i want to add a HC-SR04 to measure the distance between the robot and the floor to prevent it falling from the stairs or my desk.
but it isn’t working out that well so if somebody could help me out i would be very happy.
#include "Ultrasonic.h"
#define  TRIG_PIN  45 // object avoiding HC-SR04
#define  ECHO_PIN  44 // object avoiding HC-SR04
#define  TRIG_PIN2  43 // preventing from falling HC-SR04
#define  ECHO_PIN2  42 // preventing from falling HC-SR04
Ultrasonic OurModule2(TRIG_PIN2, ECHO_PIN2); // preventing from falling module
Ultrasonic OurModule(TRIG_PIN, ECHO_PIN); // object sensing module
#define PwmPinMotorA 49          // this is for the motor controller from dagu
#define PwmPinMotorB 50
#define DirectionPinMotorA 48
#define DirectionPinMotorB 51
int pos = 0;             // servo's position
#include <Servo.h>
Servo myservo;          // servo 1
Servo myservo2;         // servo 2
int distance = 0;
int distance2 = 0;
int distanceLeft = 0;
int distanceRight = 0;
int state = 1;        // starting state for the switchcase
  pinMode(PwmPinMotorA, OUTPUT);
  pinMode(PwmPinMotorB, OUTPUT);
  pinMode(DirectionPinMotorA, OUTPUT);
  pinMode(DirectionPinMotorB, OUTPUT);
  myservo.attach(10);
  myservo2.attach(8);
void forward(){      // driving forward
  digitalWrite(DirectionPinMotorA, HIGH);
  analogWrite(PwmPinMotorA, 150);
  digitalWrite(DirectionPinMotorB, LOW);
  analogWrite(PwmPinMotorB, 150);
void backword(){   // driving backwords
  digitalWrite(DirectionPinMotorA, LOW);
  digitalWrite(DirectionPinMotorB, HIGH);
void left(){    // turning left
  delay(300);
  analogWrite(PwmPinMotorA, 0);
  analogWrite(PwmPinMotorB, 0);
void right(){   // turning right
  analogWrite(PwmPinMotorA, 255);
  analogWrite(PwmPinMotorB, 255);
  delay(300);
void pause(){   // standing still
void Move()   // moving system for the switchcase
  distance =  OurModule.Ranging(CM);
  distance2 =  OurModule2.Ranging(CM);
  if (distance < 35)
    state = 2;
    pause();
    forward();
  if (distance2 <= 6 ){
  state = 3;
  pause();
    forward();
void Determine()    // determining witch way it has to turn system
  myservo.write(30);
  delay(400);
  distanceLeft = OurModule.Ranging(CM);
  delay(20);
  myservo.write(130);
  delay(400);
  distanceRight = OurModule.Ranging(CM);
  delay(20);
  myservo.write(80);
  if (distanceLeft <= distanceRight)
    right();
    left();
  state = 1;
void Turn180() {
     left();
     delay(3000);
     pause();
     state = 1;
    pause();
  myservo2.write(110);   // this is only for the second servo, don't mind it isn't importend
  switch (state)
  case 1: // 1 is moving
    Move();
  case 2: // 2 is Determine
    Determine();
  case 3:
     Turn180();
  default:
  pause();
but it isn't working out that well
Your explanation isn't working out at all well.
Maybe all the delays are reducing responsiveness.
Maybe, but it is difficult to tell what you expect your system to do, and what it actually does do.
You need to report what you observe, and how that is different to what you expect.
I'll offer 2 points.
1 - The spec sheet says 2cm is the minimum range. That may be approximate.
How close is your sensor from the floor? Try raising it if it's low.
  1. Are you enabling both ultrasound units at the same time?
    There could be some crosstalk. The unit listens for the telltale 8-pulse echo and gets confused by the echo from the other unit.
cas2406:
But i think you would need them because other wise the servo isn't in the right position yet before it starts to measure ?
or am i being completely wrong now ?
Rework without the delays. You can control the time things happen without only doing one thing at once. Like when you cook bacon, and eggs, at once:
