2 for loops into array maybe 2-dimentionel
Hi
I need help with this understanding about arrays and loops.
All I won is to loop throgh analogpins a0-a5 into a array
And the same with D2-D8 into array
Now I got 2 arrays
When I print it sholud be like tihs ex:
a0 100,a1 100, a2 100.... and so D2 1, D3 1, D4 1....
One long string.
How to do that and how to get it out again.
I have been trying with something like this.
AnalogPins[thisPin][] = (String)"A" + thisPin + "," + sensorReading;
Am I on the right way?
Print one long string of readings:
Serial.print("a0 ");
Serial.print(analogRead(A0));
Serial.print(", a1 ");
Serial.print(analogRead(A1));
Thanks for your answer.
Would that be the best solution, I think it will take a lot of code. instead of use for loops.
But I will go for your solution, thanks.
There are many ways to solve that problem. Arrays are fine, but a major issue with this sort of approach
is that the Arduino will probably crash after a while, due memory problems.
For this reason, most people on this forum don't recommend use of String objects with Arduino.
