2 fuctions at the same time
guys
I have the remote car by bluetooth + arduino working fine, but when it goes back I’d like that the led blink. What do I do?
#include “SoftwareSerial.h”
#include <Servo.h>
int pinIn1=4; //motor1
int pinIn2=5; //motor1
int pinIn3=6; //motor2
int pinIn4=7; //motor2
SoftwareSerial bluetooth(2,3);
int entradaDados;
bluetooth.begin(9600);
pinMode(pinIn1, OUTPUT);
pinMode(pinIn2, OUTPUT);
pinMode(pinIn3, OUTPUT);
pinMode(pinIn4, OUTPUT);
pinMode(13, OUTPUT);
if (bluetooth.available() > 0) {
entradaDados = bluetooth.read();
if (entradaDados == ‘F’) {
Frente(); //Goes Forward
if (entradaDados == ‘R’) {
Retroceder(); //Goes Back
if (entradaDados == ‘D’) {
Direita(); //Goes Right
if (entradaDados == ‘E’) {
Esquerda(); //Goes Left
if (entradaDados == ‘P’) {
Parada(); //Stop
void Frente()
digitalWrite(pinIn1, HIGH);
digitalWrite(pinIn2, LOW);
digitalWrite(pinIn3, HIGH);
digitalWrite(pinIn4, LOW);
digitalWrite(13, HIGH);
void Retroceder(){
digitalWrite(pinIn1, LOW);
digitalWrite(pinIn2, HIGH);
digitalWrite(pinIn3, LOW);
digitalWrite(pinIn4, HIGH);
delay(900);
digitalWrite(13, LOW);
delay(900);
delay(900);
delay(900);
delay(900);
delay(900);
void Direita(){
void Esquerda(){
void Parada(){
get rid of delay() and use millis() to do timing.
look here for references: millis() for beginners
If millis() will be working as delay() here why to use it?
surepic:
If coded correctly, won't be. OP needs to implement a State Machine.
Also worth observing - the use of tags was an admirable effort, but please use tags next time (or edit your original post!
The formatting is different when displayed - thanks
leandrogalves:
I have the remote car by bluetooth + arduino working fine, but when it goes back I'd like that the led blink. What do I do?
Have a look at how it is done in Several Things at a Time
You can't actually run two functions at the same time but you can make it appear like that by doing a little piece of each function interleaved with a little piece of the other function. Note how each function runs very briefly and returns to loop() so the next one can be called. Long running processes are achieved a tiny piece at a time. And there may be dozens of calls to some functions before it is actually time for anything to happen.
...R
