2 H bridges driving one motor?
If I was to connect the outputs of both sides of an H bridge to a single motor, would I get twice the amperage?
and also, if I was to connect one side of one hbridge, and one side of another h bridge to a single motor, would i receive the same result?
If you were using bipolar transistors such as the pnp2907 or ones like that you would get moore current but if you used a MOSEFET I think that gives you as much current as the power source supplies. It depends on what type of H-bridge you are using.
Well thanks anyway, I'll just test it out and hope not to blow anything.
It will only blow up if you give each bridge different direction commands.
If you were using bipolar transistors such as the pnp2907 or ones like that you would get more current but if you used a MOSEFET I think that gives you as much current as the power source supplies
Wrong way round, a MOSFET would share the load where as a transistor would not. So there is no point in doing it if you have transistors in your bridge.
Yeah, figured. Thanks tho.
