2 I2C and 1 UART are not working simultaneously in ESP32
I have a project in which I have to monitor Acceleration of the subject, Location and Pulse + SpO2 of the subject. So, I've written this program to check data from MAX30100 Pulse Oxi sensor and MPU6050 Accelero and Gyroscope sensor using ESP32 -
This program works completely fine. No issues at all.
#include <Wire.h>
    #include "MAX30100_PulseOximeter.h"
    #define REPORTING_PERIOD_MS 1000
    #define BLYNK_PRINT Serial
    #include <Blynk.h>
    #include <WiFi.h>
    #include <BlynkSimpleEsp32.h>
    char auth[] = "*********************";
    // For Pulse sensor
    PulseOximeter pox;
    float BPM, SpO2;
    uint32_t tsLastReport = 0;
    // For Accelerometer sensor
    const int MPU_addr=0x68;
    int16_t accelX, accelY, accelZ, gyroX, gyroY, gyroZ;
    float gForceX, gForceY, gForceZ,rotX, rotY, rotZ;
    void onBeatDetected()
        Serial.println("Beat Detected!");
      WiFi.begin("TP-Link", "**********");
      // Wait for wifi to be connected
      uint32_t notConnectedCounter = 0;
          delay(100);
          Serial.println("Wifi connecting...");
          notConnectedCounter++;
          if(notConnectedCounter > 50) { // Reset board if not connected after 5s
              Serial.println("Resetting due to Wifi not connecting...");
              ESP.restart();
      Serial.print("Wifi connected, IP address: ");
      Blynk.begin(auth,"TP-Link_380B", "installation*500");
      Serial.println("Initializing Pulse Oximeter..");
        if (!pox.begin())
             Serial.println("FAILED");
             for(;;);
             Serial.println("SUCCESS");
             pox.setOnBeatDetectedCallback(onBeatDetected);
        // The default current for the IR LED is 50mA and it could be changed by uncommenting the following line.
            pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
      Wire1.begin(32,33,100000);
      Wire1.beginTransmission(MPU_addr);
      Wire1.write(0x6B);  // PWR_MGMT_1 register
      Wire1.write(0);     // set to zero (wakes up the MPU-6050)
      Wire1.endTransmission(true);
      // Reading data from Accelerometer sensor
      Wire1.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
      Wire1.endTransmission(false);
      Wire1.requestFrom(MPU_addr,14,true);  // request a total of 14 registers
      accelX=Wire1.read()<<8|Wire1.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
      accelY=Wire1.read()<<8|Wire1.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
      accelZ=Wire1.read()<<8|Wire1.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
      gyroX=Wire1.read()<<8|Wire1.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
      gyroY=Wire1.read()<<8|Wire1.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
      gyroZ=Wire1.read()<<8|Wire1.read();
      gForceX = (accelX-2050) / 16384.0;
      gForceY = (accelY-77) / 16384.0;
      gForceZ = (accelZ-1947) / 16384.0;
      rotX = (gyroX+270) / 131.0;
      rotY = (gyroY-351) / 131.0;
      rotZ = (gyroZ+136) / 131.0;
      // calculating Amplitute vactor for 3 axis
      float Raw_Amp = pow(pow(gForceX,2)+pow(gForceY,2)+pow(gForceZ,2),0.5);
      int Amp = Raw_Amp * 10;  // Mulitiplied by 10 bcz values are between 0 to 1
      int angleChange = pow(pow(rotX,2)+pow(rotY,2)+pow(rotZ,2),0.5);
      // Reading data from pulseoximeter sensor
      pox.update();
      BPM = pox.getHeartRate();
      SpO2 = pox.getSpO2();
      // Uploading data to Blynk server AND printing data on serial monitor
      if (millis() - tsLastReport > REPORTING_PERIOD_MS)
          Blynk.run();
          Blynk.virtualWrite(V3, BPM);
          Blynk.virtualWrite(V4, SpO2);
          Serial.println(Amp);
          Serial.println(angleChange);
          Serial.print("Heart rate:");
          Serial.print(BPM);
          Serial.print(" bpm / SpO2:");
          Serial.print(SpO2);
          Serial.println(" %");
          tsLastReport = millis();
Now I added GPS, so that I can track the location too. And GPS is working along with accelerometer but Pulse oximeter sensor is not working - Output from that is 0 and the rest of the sensors are producing the expected outputs. Program for that is given below
#include <TinyGPSPlus.h>
    #include <HardwareSerial.h>
    #include <Arduino.h>
    #include <Wire.h>
    #include <Blynk.h>
    #include <WiFi.h>
    char auth[] = "*****************";
    // For GPS sensor
    float latitude , longitude;
    String  latitude_string , longitiude_string;
    TinyGPSPlus gps;
    WidgetMap myMap(V0);
    HardwareSerial SerialGPS(2);
    // For Pulse sensor
    PulseOximeter pox;
    float BPM, SpO2;
      WiFi.begin("TP-Link", "***********");
          delay(100);
              ESP.restart();
      Blynk.begin(auth,"TP-Link", "*************");
      // Pulse oximeter setup
        if (!pox.begin())
             for(;;);
      // Accelerometer setup
     // GPS Setup
     SerialGPS.begin(9600, SERIAL_8N1, 16, 17);
      pox.update();
      // Reading the data from GPS
      if(SerialGPS.available() > 0) {
        if (gps.encode(SerialGPS.read()))
          if (gps.location.isValid())
            latitude = gps.location.lat();
            latitude_string = String(latitude , 6);
            longitude = gps.location.lng();
            longitiude_string = String(longitude , 6);
          Blynk.run();
          Serial.print(BPM);
          Serial.print(SpO2);
          Blynk.virtualWrite(V0, 1, latitude, longitude, "Location");
          Serial.print("Latitude = ");
          Serial.println(latitude_string);
          Serial.print("Longitude = ");
          Serial.println(longitiude_string);
Will you please help me with this. What's wrong with the program.
