Hi All,
I have 2 38 mhz recievers (TSOP 38438). I can get pin B to detect on both of my circuits. I'm having an issue with pin a.
My end goal is anytime either beam is broken, it triggers an Output "switch" for a few seconds.
I really appreciate the help in advance. I've tried (using Iremote) library...
#include <IRremote.h>
#define LEDPIN_A 13
#define PINIR_A 2
#define PINIR_B 4
#define SENSORPIN_A 5
#define SENSORPIN_B 6
// variables will change:
int sensorState_A = 0, lastState_A = 0;
int sensorState_B = 0, lastState_B = 0;
IRsend irsend;
// initialize the LED pin as an output:
pinMode(LEDPIN_A, OUTPUT);
// initialize the sensor pins as an input and enable internal pullup:
pinMode(SENSORPIN_A, INPUT_PULLUP);
pinMode(SENSORPIN_B, INPUT_PULLUP);
//set carrier frequency
irsend.enableIROut (38);
irsend.mark (0);
// read the state of the sensor:
sensorState_A = digitalRead(SENSORPIN_A);
sensorState_B = digitalRead(SENSORPIN_B);
// check if the sensor beam is broken
// if it is, the sensorState is LOW:
if (sensorState_A == LOW)
// turn LED on:
digitalWrite(LEDPIN_A, HIGH);
// turn LED off:
digitalWrite(LEDPIN_A, LOW);
if (sensorState_A && !lastState_A)
Serial.println("A Unbroken");
if (!sensorState_A && lastState_A)
Serial.println("A Broken");
lastState_A = sensorState_A;
if (sensorState_B == LOW)
// turn LED on:
// turn LED off:
if (sensorState_B && !lastState_B)
Serial.println("B Unbroken");
if (!sensorState_B && lastState_B)
Serial.println("B Broken");
lastState_B = sensorState_B;
delay(500); // so we don't flood the serial port
