2 ir sensors line follower code
Hi all,
i am in urgent need to improve this code to stop at the 17th black line ,so i need to know how to write a counter that can count black lines and stop at end which is the 17th black line.
thanks in advance.
/*------ Line Follower ---- */
/*-------definning Inputs------*/
#define LS 2         // left sensor
#define RS 3        // right sensor
/*-------definning Outputs------*/
#define LM1 4       // left motor
#define LM2 5       // left motor
#define RM1 6       // right motor
#define RM2 7       // right motor
pinMode(LS, INPUT);
pinMode(RS, INPUT);
pinMode(LM1, OUTPUT);
pinMode(LM2, OUTPUT);
pinMode(RM1, OUTPUT);
pinMode(RM2, OUTPUT);
if(digitalRead(LS) && digitalRead(RS))        // Move Forward
 digitalWrite(LM1, HIGH);
 digitalWrite(LM2, LOW);
 digitalWrite(RM1, HIGH);
 digitalWrite(RM2, LOW);
if(!(digitalRead(LS)) && digitalRead(RS))     // Turn right
 digitalWrite(LM1, LOW);
if(digitalRead(LS) && !(digitalRead(RS)))     // turn left
 digitalWrite(RM1, LOW);
if(!(digitalRead(LS)) && !(digitalRead(RS)))     // I need to make counter here to stop after 17th condition
You need to see the state change example in the IDE.
You also need to use code tags when posting code.
You do not need to read the pins 4 times, to make 4 decisions. Learn about else if statements, too.
above code does not work please help me
