Hi designer2k2, your project is very nice! I’m trying to use pachube too, but have some troubles understanding the code of the example you used. Where did you read in the Arduino code your sensors…?
Should be around here:
// call 'pachube_in_out' at the beginning of the loop, handles timing, requesting
// and reading. use serial monitor to view debug messages
pachube_in_out();
// then put your code here, you can access remote sensor values
// by using the remoteSensor float array, e.g.:
analogWrite(3, (int)remoteSensor[3] * 10); // remoteSensor is a float
analogWrite(5, (int)remoteSensor[1]);
// you can have code that is time sensitive (e.g. using 'delay'), but
// be aware that it will be affected by a short pause during connecting
// to and reading from ethernet (approx. 0.5 to 1 sec).
// e.g. this code should carry on flashing regularly, with brief pauses
// every few seconds during Pachube update.
digitalWrite(6, HIGH);
delay(100);
digitalWrite(6, LOW);
delay(100);
And what’s the “remote sensor”, I actually don’t need to read other’s pachube sensors feed.
Hope you have clearer ideas than mine… :-/
the inputs have changed, so my old first post is wrong ;)
but the output sensor ist not right, currently we have around -5°C at night but the sensor never goes below 3°C as the LM35 in basic circuit cannot show negative numbers...
