Hi!
I'm wondering if I can use 2 motor shields at thesame time, a servo shield and a dc motor shield.
Stijn.
Hi!
Stijn.
I suspect that multiple shields are going to conflict with each other. The problem is that they are likely to be using the some output pins from the Arduino.
Check the docs on the shields carefully to see which control lines/pins are being used. If there is overlap between the boards, you're going to have trouble....
