byronas
1
I want to use 2 or more rfid readers to read two cards and check if the correct card is on the correct reader!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// Number of Readers
int no_Readers = 2;
// Pin Definition
#define PN532_SCK (52)
#define PN532_MOSI (51)
//#define PN532_SS (10)
#define PN532_MISO (50)
#define PN532_SS_1 10
#define PN532_SS_2 9
//#define PN532_SS_3 8
//#define PN532_SS_4 7
#define controlledOutput 5
// Arrays for saved UIDs
uint8_t savedUIDs[][7] = {
{ 0x43, 0xFC, 0x6B, 0xA9},
{ 0xA2, 0x1E, 0x3D, 0x51}
// Adafruit_PN532 Objects
Adafruit_PN532 nfc[] = {
Adafruit_PN532(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS_1),
Adafruit_PN532(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS_2),
//Adafruit_PN532 (PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS_3),
//Adafruit_PN532 (PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS_4)
void setup(void) {
pinMode(controlledOutput, OUTPUT);
while (!Serial) delay(10);
for (int i = 0; i < no_Readers; ++i) {
// Setup and Check Scanner
nfc[i].begin();
uint32_t versiondata = nfc[i].getFirmwareVersion();
if (!versiondata) {
Serial.print("Scanner ");
Serial.print(i + 1);
Serial.println(": PN53X board not found");
while (1)
//nfc[i].SAMConfig();
Serial.println("found");
Serial.println("Waiting for Card ...");
// ... (other functions)
void loop(void) {
uint8_t uid[] = { 0, 0, 0, 0 };
uint8_t uidLength;
if (nfc[i].startPassiveTargetIDDetection(PN532_MIFARE_ISO14443A)) {
uint8_t success = nfc[i].readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
if (success) {
Serial.print(" UID Value ");
Serial.print(i);
Serial.print(" : ");
nfc[i].PrintHex(uid, uidLength);
if (!nfc[i].startPassiveTargetIDDetection(PN532_MIFARE_ISO14443A)) {
//Serial.print("Scanner ");
//Serial.print(i + 1);
//Serial.println(": UID Not found");
//savedUIDs[]
if (compareArrays(uid[i], savedUIDs[i], 4)) {
// 4 Successful keys Detected
//Serial.println();
Serial.println("Unlocked!");
digitalWrite(controlledOutput, HIGH);
//delay(1000);
//Serial.println();
//Serial.println("Locked!");
digitalWrite(controlledOutput, LOW);
// delay(1000);
bool compareArrays(uint8_t arr1[], uint8_t arr2[], int length) {
for (int i = 0; i < length; i++) {
if (arr1[i] != arr2[i]) {
return false;
return true;
byronas
3
it won't compare the cards!
what is wrong with the code?
Have you tried printing the values that are being compared ro see if they are what you expect them to be ?
byronas
5
Serial.print(arr1[i] );
Serial.print (" : ");
Serial.print(arr2[i] );
Serial.println (" ");
return false;
Serial.println("true");
return true;
i get :
1600734 : 162306181
1600494 : 67252107169
why?
Make things clearer by printing the array elements in HEX with a space between them
byronas
7
I get :
UID Value 0 : 0x43 0xFC 0x6B 0xA9
0 3 3 19 : 43 FC 6B A9
UID Value 1 : 0xA2 0x1E 0x3D 0x51
1E 0 0 0 : A2 1E 3D 51
byronas
8
Thanks i guess you helped me!!!!!
this now works!!!!
#include <Wire.h>
#include <SPI.h>
const byte no_Readers = 2;
// Pin Definition
String currentIDs[no_Readers];
const String correctIDs[] = { "2719890769", "1140616105" };
void setup(void) {
nfc[i].begin();
if (!versiondata) {
while (1)
void loop(void) {
boolean puzzleSolved = false;
uint8_t uidLength;
if (success) {
Serial.print(i);
if (uidLength == 4) {
// We probably have a Mifare Classic card ...
uint32_t cardid = uid[0];
cardid <<= 8;
cardid |= uid[1];
cardid <<= 8;
cardid |= uid[2];
cardid <<= 8;
cardid |= uid[3];
Serial.print("Seems to be a Mifare Classic card #");
Serial.println(cardid);
currentIDs[i] = cardid;
if (currentIDs[0] == correctIDs[0] && currentIDs[1] == correctIDs[1]) {
// The puzzle has not been solved
puzzleSolved = true;
} else{puzzleSolved = false;
Serial.println("false");
if(puzzleSolved){
Please explain what the probkem was and how you fixed it
system
Closed
10
