my pinmode output 5 and 6 dont work with this code but will work when they are stand alone. What is causing the arduino to not output anything from these outputs within my code?
Heres the code:
#include <SoftwareSerial.h> // use the software serial library
SoftwareSerial mySerial(3,4); // receive data at pin 3; transmit data at pin 2
int setpoint;
float val;
int roomtemp;
int UCL;
int LCL;
float salinity;
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(3,OUTPUT);
pinMode(2, OUTPUT);
roomtemp=25;
setpoint=7.0291*roomtemp+334.73;
UCL=setpoint+6.12;
LCL=setpoint-6.12;
Serial.print("Setpoint =");
Serial.print(setpoint);
Serial.print("Degrees Celsius");
Serial.print("UCL =");
Serial.print(UCL);
Serial.print("LCL =");
Serial.print(LCL);
mySerial.begin(9600); delay(500); // set data rate to 9600 baud; wait for bootup
mySerial.write(254); mySerial.write(128);
mySerial.write(254); mySerial.write(1); // clear screen & move to top left position
mySerial.write(254); mySerial.write(132);
mySerial.print("LCL");
mySerial.write(254); mySerial.write(139);
mySerial.print("SP");
mySerial.write(254); mySerial.write(144);
mySerial.print("UCL");
mySerial.write(254); mySerial.write(192);
mySerial.print("S:");
mySerial.write(254); mySerial.write(195);
mySerial.print(0.072,3);
mySerial.write(254); mySerial.write(201);
mySerial.print(0.100,3);
mySerial.write(254); mySerial.write(207);
mySerial.print(0.108,3);
mySerial.write(254); mySerial.write(148);
mySerial.print("T:");
mySerial.write(254); mySerial.write(152);
mySerial.print("24.1");
mySerial.write(254); mySerial.write(158);
mySerial.print("25.0");
mySerial.write(254); mySerial.write(164);
mySerial.print("25.9");
mySerial.write(254); mySerial.write(212);
mySerial.print("S=");
mySerial.write(254); mySerial.write(220);
mySerial.print("T=");
int val=analogRead(5);
Serial.print("Analog Value =");
Serial.print(val);
Serial.print("Temperature =");
Serial.println((0.14227val)-47.621);
if(val<LCL) digitalWrite(3,HIGH);
else if(val>UCL) digitalWrite(3,LOW);
mySerial.write(254); mySerial.write(227);
if(val<LCL) mySerial.write("H= ON");
if(val>UCL) mySerial.write("H=OFF");
digitalWrite(2, HIGH);
delay(100);
int analogS=analogRead(4);
digitalWrite(2, LOW);
Serial.println(analogS);
salinity = 2.0955pow(10,-19)pow(analogS,5.8106)100.000;
Serial.print("Salinity =");
Serial.println(salinity);
mySerial.write(254); mySerial.write(214);
mySerial.print(salinity);
mySerial.write(254); mySerial.write(222);
mySerial.print((0.14227val)-47.621,1);
Serial.println("analog value");
Serial.print(analogRead(4));
float target= (salinity-(salinity-.1).60);
float numer=((((target).08585-(salinity).08585)/(.1-(.1*.15+salinity*.85)))*60.0);
float denom= ((.1));
float valve= ((numer/denom)/10.00);
if(.096.104){
delay(5000);
}if(salinity>.104){
Serial.print("Entering DIon Function");
digitalWrite(6,HIGH);
delay(valve);
digitalWrite(6,LOW);
delay(5000);
if(salinity<.096){
Serial.print("Entering Saltyon Function");
digitalWrite(5,HIGH);
delay(valve);
digitalWrite(5,LOW);
delay(5000);
Serial.print("time");
Serial.println(valve);
