2 piezo switches with diverent instructions to the same pin.
Hi
I am working on a e-surfboard prototype to help me get into waves. I have a shoulder injury that is not going to get any better and I need some paddle assistants.
I have 2 thruster motors that are controlled by 2 electronic speed controllers that get a signal from my Arduino. At the moment I have 1 Piezo switch that gives the instruction to the Arduino to send the program to the esc’s. I would like to add another piezo switch to be able to send a second program to the esc’s. Something like 2 minutes at 50 % thrust. I hope someone on this forum can write the code for me. Because I really don’t understand it. The code I have now is written for me as well. I can make small changes in thrust and time but that is about it. I try to understand it and did some internet searches and read a book about it but it looks like acradabra (Chinese, French or any other languages that is not dutch) to me.
Please help me out I want to be able to go surfing again.
this is the code I have now feel free to alter it and reply.
//By Adam Šimko for Bart de Rooij
//Blue Robotics T200 Surfboard Paddle Assist
//Jan 03 2017
#include <Servo.h> //include servo control library to operate ESC
//start critial values to edit as desired
#define BUTTON 10 //momentary button switch on digital pin 10
#define THRUSTERS 5 //thruster ESCs on digital pin 5
#define THRUST1 0.1 //initial thrust level for both thrusters after button press (decimal percent, i.e. 10% = 0.1)
#define TIME1 5 //thrust time at thrust level 1 (seconds)
#define THRUST2 0.20 //thrust level for both thrusters after end thrust1 (decimal percent, i.e. 20% = 0.2)
#define TIME2 5 //thrust time at thrust level 1 (seconds)
#define THRUST3 0.3 //initial thrust level for both thrusters after button press (decimal percent, i.e. 30% = 0.3)
#define TIME3 5 //thrust time at thrust level 1 (seconds)
#define THRUST4 0.15 //thrust level for both thrusters after end thrust1 (decimal percent, i.e. 15% = 0.15)
#define TIME4 5 //thrust time at thrust level 1 (seconds)
int throttleChangeDelay = 1; //delay in milliseconds per microsecond of PWM value change (i.e. deault of one means 400ms time from 1500us to 1900us, or stopped to full throttle)
//end critial values to edit as desired
int currentThrottle = 1500; //initial throttle value
int changeThrottle; //initial empty throttle value to change to
int pushButton = BUTTON; //momentary push button attached to digital pin 10 and GND
bool buttonPushed; //pushbutton has only two states
Servo esc; //Servo function named esc
pinMode(pushButton, INPUT); //set pushButton as an input
pinMode(BUTTON, INPUT); //pin 10 is input to push button is connected
digitalWrite(BUTTON, HIGH); //makes pin 10 high (5v)
esc.attach(THRUSTERS); //attaches ESCs to THRUSTERS pin
esc.writeMicroseconds(1500); // send “stop” signal to ESC.
delay(1000); // delay to allow the ESC to recognize the stopped signal
int buttonState = digitalRead(pushButton); //reads the state of push button
if ( buttonState == 0 ) { //if button is making contact with ground
changeThrottle = (1500 + (THRUST1 * 400)); //set thrusters to THRUST1…
smooth(); //uses smooth function to get to throttle value
delay(TIME1 * 1000); //…for TIME1
changeThrottle = (1500 + (THRUST2 * 400)); //set thrusters to THRUST2…
delay(TIME2 * 1000); //…for TIME2
changeThrottle = (1500 + (THRUST3 * 400)); //set thrusters to THRUST3…
delay(TIME3 * 1000); //…for TIME1
changeThrottle = (1500 + (THRUST4 * 400)); //set thrusters to THRUST4…
delay(TIME4 * 1000); //…for TIME2
changeThrottle = 1500; //stops thrusters
if ( buttonState == 1 ) { //if button is not making contact with ground
esc.writeMicroseconds(1500); //keep thrusters stopped
void smooth() { //smooth function to transition smoothly between throttle values
// Are we going up or down?
int step = 1; //steps up by 1 per cycle
if ( changeThrottle < currentThrottle ) //if decreasing throttle
step = -1; //or down by 1 per cycle
// Slowly move to the new throttle value
while ( currentThrottle != changeThrottle ) { //while current throttle different from desired throttle
esc.write(currentThrottle + step); //stup us throttle by 1us per cycle
currentThrottle = currentThrottle + step; //changes current throttle to new current throttle
delay(throttleChangeDelay); //delay cyacle
No, it does not. You can send pulses to the ESCs, NOT programs.
That code reads a digital pin. Piezos are typically connected to analog pins.
Hi Paul thanks for the correction.
Is there any change that you will creat the additional code so i have two options. the one in my first post and another one with 2 minutes 50%. I guess you know how sadly I don't.
I would be really thankfull if you would.
Kind regards,
Bart
