anyone has a clear fritzing graphics on how to connect two PIR sensors with one servo?
I am using the code below:
const int switchPin = 2; // switch input
const int motor1Pin = 3; // H-bridge leg 1 (pin 2, 1A)
const int motor2Pin = 4; // H-bridge leg 2 (pin 7, 2A)
const int enablePin = 9; // H-bridge enable pin
// set the switch as an input:
pinMode(switchPin, INPUT);
// set all the other pins you're using as outputs:
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(enablePin, OUTPUT);
pinMode(ledPin, OUTPUT);
// set enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// if the switch is high, motor will turn on one direction:
if (digitalRead(switchPin) == HIGH) {
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge high
// if the switch is low, motor will turn in the other direction:
else {
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge low
(please use the # button to get code tags)
I would connect the PIR’s both to their own pin and merge the signal in software
something like this
const int switchPin1 = 2;  // switch input PIR1
const int switchPin2 = 5;  // switch input PIR2
Â
  pinMode(switchPin1, INPUT);
  pinMode(switchPin2, INPUT);
Â
  // if one of the switches is high, motor will turn on one direction:
  if ((digitalRead(switchPin1) == HIGH) || (digitalRead(switchPin2) == HIGH))
  else {
