I'm trying to power one motor(including driver), whith 2 power supplies
WARNING to avoid problems whith voltage issues, I added 2 relays in break of positive wire out of first power supply & turn on them sequentally whith delay of a few seconds
but motor run only when only one relay is in circuit
I tried to add diodes on positive wire out of first and second relay, but it didn't work either
SO, what do I do now?
I will appreciate if smbd give me a scheme how properly 2 power supplies are connected in one circuit, receiving any ideas
What is the problem that you're trying to solve with the two power supplies (what kind of voltage issues); would one bigger power supply not work better?
Didn't work - what exactly happened? Were the two supplies set to precisely the same voltage beforehand, and were the diodes you used as close to identical as possible? Both matter.
