2 segments from 1 digit display not working
So I’m just testing with a 7 segment led display, and it turns out 2 segments aren’t working(f & g). Is there a way to solve it?
Sure, undo the screws holding it together & replae the LEDs.
Can you confirm with a 5V supply and say a 1K resistor that the segments actually work?
If it is common anode connect the anode to +5, and try each segment with the resistor to Gnd.
If is common cathode, connect the cathode to Gnd, and try each segment with the resistor to +5.
If the segments turn on, then you have a wiring problem, a software problem, or a problem with the hardware you are controlling the display with.
CrossRoads:
I’ve tried that, all segments turn on, except f & g. So would that mean that the 2 segments are broken?
Yes, it sounds like the digits are damaged/faulty.
