2 Sensors 1 board no results, Programming error?
Hello,
I'm relatively new to Arduino and I'm trying to use 2 sensors on one board.
Right now I am getting no error in the console yet my serial monitor is not returning any value.
I'm basically trying to splice 2 separate sketches that worked independently. Is it a problem with the structure of my sketch?
Also I'm wanting to be able to access the values of each sensor, how can I return the value to use with other functions?
My sensors
1 - HC-SR04 "classic"
2 - HC-SR501
My code
//this is the head program containing sections for
//ping
//pir
//speaker
//led's
////import any libs needed
//#include <Wire.h>
//initial global variables
//pir variables
int pir_val = 0;
int pir_vcc = 6;
int pir_sig = 7;
int pir_gnd = 8;
int pirState = LOW;             // we start, assuming no motion detected
//ping variables
int ping_val = 0;
int ping_vcc = 2;
int ping_trig = 3;
int ping_echo = 4;
int ping_gnd = 5;
//speaker
int speaker = 10;
void setup(){
 pir_setup();
 ping_setup();
void loop(){
ping();
delay(10);
pir();
delay(10);
void ping_setup(){
  pinMode (ping_trig, OUTPUT);//attach pin 2 to vcc
  pinMode (ping_echo,INPUT);//attach pin 5 to GND
void pir_setup(){
  pinMode(pir_vcc, OUTPUT);
  pinMode(pir_gnd, OUTPUT);
  pinMode(pir_sig, INPUT);     // declare sensor as input
void ping(){
digitalWrite(ping_vcc, HIGH);
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
//  pinMode(ping_trig, OUTPUT);// attach pin 3 to Trig
  digitalWrite(ping_trig, LOW);
  delayMicroseconds(2);
  digitalWrite(ping_trig, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
//  pinMode (ping_echo, INPUT);//attach pin 4 to Echo
  duration = pulseIn(ping_echo, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  ping_val = cm;
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
//return cm;
digitalWrite(ping_vcc, LOW);
  delay(25);
void pir(){
  digitalWrite(pir_vcc, HIGH);
  pir_val = digitalRead(pir_sig);  // read input value
  if (pir_val == HIGH) {            // check if the input is HIGH
    delay(15);
    if (pirState == LOW) {
      // we have just turned on
      Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH;
      delay(30);
      if (pirState == HIGH){
      // we have just turned of
      Serial.println("Motion ended!");
      pirState = LOW;
  digitalWrite(pir_vcc, LOW);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
int pir_gnd = 8;
Does that mean that you have ground of the PIR sensor connected to pin 8?
int ping_gnd = 5;
Does that mean that you have ground of the PING sensor connected to pin 5?
If either of them are true, connect the grounds to the ground pin!
The ping_gnd pin is not set to OUTPUT and is not set LOW, so the ping sensor is not grounded.
The pir_gnd pin is set to OUTPUT, but it is not set to LOW, so the pir sensor may not be grounded.
Add Serial.print() statements to setup() and loop(). Find out where the code is waiting for something to happen.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
This will help better than a thousand words.
Tom...... :slight_smile:
