2 sensors and RTC activating a relay
I’m currently building a silencer box for my air compressor. To regulate when the compressor turns on I build the following circuit ( See attached picture)
Desired function of the circuit:
  • The relay can only switch on between 9:00-20:00 (to prevent compressor switching on by night)
  • The relay can only switch on when the PIR sensor is HIGH (only switching on when I’m home)
  • When temperature in the silencer box reaches 140°F the relay has to switch off and wait 10 minutes to cool down (overheating protection)
Note: the compressor has his own pneumatic switch that switches ON when the pressure drops down a certain level and switches OFF when tank is full. So there is no need to switch relay on/off for this purpose.
Watching several YouTube tutorials got me the code to work with the Thermistor and PIR one at the time. And I found some code to program the RTC
// 10 k thermistor code
#include <math.h>
int relayPin = 6;
double Thermistor(int RawADC) {
 double Temp;
 Temp = log(10000.0*((1024.0/RawADC-1)));
 Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
 Temp = Temp - 273.15;
 Temp = (Temp * 9.0)/ 5.0 + 32.0;
 return Temp;
  pinMode(6, OUTPUT);
  int val;
  double temp;
  val=analogRead(0);
  temp=Thermistor(val);
  Serial.print("Temperature = ");
  Serial.print(temp);
  Serial.println(" F");
  if (temp >= 140){
    digitalWrite(relayPin, LOW);
  else {
    digitalWrite(relayPin, HIGH);
// pir code
int relayPin = 6;  // LED on Pin 13 of Arduino
int pirPin = 7; // Input for HC-S501
int pirValue; // Place to store read PIR Value
  pinMode(relayPin, OUTPUT);
  pinMode(pirPin, INPUT);
  pirValue = digitalRead(pirPin);
  digitalWrite(relayPin, pirValue);
// RTC code
#include <Wire.h>
#include "ds3231.h"
#define BUFF_MAX 128
uint8_t time[8];
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 5000;
void parse_cmd(char *cmd, int cmdsize);
    Wire.begin();
    DS3231_init(DS3231_INTCN);
    memset(recv, 0, BUFF_MAX);
    Serial.println("GET time");
    //parse_cmd("T004309704062017", 16);
    char in;
    char buff[BUFF_MAX];
    unsigned long now = millis();
    struct ts t;
    // show time once in a while
    if ((now - prev > interval) && (Serial.available() <= 0)) {
        DS3231_get(&t);
        // there is a compile time option in the library to include unixtime support
#ifdef CONFIG_UNIXTIME
        snprintf(buff, BUFF_MAX, "%d.%02d.%02d %02d:%02d:%02d %ld", t.year,
             t.mon, t.mday, t.hour, t.min, t.sec, t.unixtime);
#else
        snprintf(buff, BUFF_MAX, "%d.%02d.%02d %02d:%02d:%02d", t.year,
             t.mon, t.mday, t.hour, t.min, t.sec);
#endif
        Serial.println(buff);
        prev = now;
    if (Serial.available() > 0) {
        in = Serial.read();
        if ((in == 10 || in == 13) && (recv_size > 0)) {
            parse_cmd(recv, recv_size);
            recv_size = 0;
            recv[0] = 0;
        } else if (in < 48 || in > 122) {;       // ignore ~[0-9A-Za-z]
        } else if (recv_size > BUFF_MAX - 2) {   // drop lines that are too long
            // drop
            recv_size = 0;
            recv[0] = 0;
        } else if (recv_size < BUFF_MAX - 2) {
            recv[recv_size] = in;
            recv[recv_size + 1] = 0;
            recv_size += 1;
    uint8_t i;
    uint8_t reg_val;
    struct ts t;
    //snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
    //Serial.print(buff);
    // TssmmhhWDDMMYYYY aka set time
    if (cmd[0] == 84 && cmdsize == 16) {
        //T355720619112011
        t.sec = inp2toi(cmd, 1);
        t.min = inp2toi(cmd, 3);
        t.hour = inp2toi(cmd, 5);
        t.wday = cmd[7] - 48;
        t.mday = inp2toi(cmd, 8);
        t.mon = inp2toi(cmd, 10);
        t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
        DS3231_set(t);
        Serial.println("OK");
    } else if (cmd[0] == 49 && cmdsize == 1) {  // "1" get alarm 1
        DS3231_get_a1(&buff[0], 59);
    } else if (cmd[0] == 50 && cmdsize == 1) {  // "2" get alarm 1
        DS3231_get_a2(&buff[0], 59);
    } else if (cmd[0] == 51 && cmdsize == 1) {  // "3" get aging register
        Serial.print("aging reg is ");
        Serial.println(DS3231_get_aging(), DEC);
    } else if (cmd[0] == 65 && cmdsize == 9) {  // "A" set alarm 1
        DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
        //ASSMMHHDD
        for (i = 0; i < 4; i++) {
            time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
        uint8_t flags[5] = { 0, 0, 0, 0, 0 };
        DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
    } else if (cmd[0] == 66 && cmdsize == 7) {  // "B" Set Alarm 2
        DS3231_set_creg(DS3231_INTCN | DS3231_A2IE);
        //BMMHHDD
            time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
        uint8_t flags[5] = { 0, 0, 0, 0 };
        DS3231_set_a2(time[0], time[1], time[2], flags);
    } else if (cmd[0] == 67 && cmdsize == 1) {  // "C" - get temperature register
        Serial.print("temperature reg is ");
        Serial.println(DS3231_get_treg(), DEC);
    } else if (cmd[0] == 68 && cmdsize == 1) {  // "D" - reset status register alarm flags
        reg_val = DS3231_get_sreg();
        reg_val &= B11111100;
        DS3231_set_sreg(reg_val);
    } else if (cmd[0] == 70 && cmdsize == 1) {  // "F" - custom fct
        reg_val = DS3231_get_addr(0x5);
        Serial.print("orig ");
        Serial.print(reg_val,DEC);
        Serial.print("month is ");
        Serial.println(bcdtodec(reg_val & 0x1F),DEC);
    } else if (cmd[0] == 71 && cmdsize == 1) {  // "G" - set aging status register
        DS3231_set_aging(0);
    } else if (cmd[0] == 83 && cmdsize == 1) {  // "S" - get status register
        Serial.print("status reg is ");
        Serial.println(DS3231_get_sreg(), DEC);
        Serial.print("unknown command prefix ");
        Serial.println(cmd[0]);
        Serial.println(cmd[0], DEC);
Unfortunately I got stuck at this point. Any help, by showing me how to combine this code, would be very much appreciated!
have a great day
MB
You can't have two setup() and two loop() functions. You CAN do everything that each setup() does in the one setup() function. Ditto for the loop() function.
