2 Serial Port GPS Receive on MEGA 2560
Hi All,
I've been playing around with 2 GPS receivers on my Mega 2560. I wanted to get 1 Hz NMEA data from both units using the UARTS (serial 1 and 2) and then display it. So, based on the examples in the Tiny GPS library, I have come up with this:
#include <TinyGPS.h>
For Mega 2560
9600 baud serial GPS device hooked up on Serial 1.1Hz NMEA data.
9600 baud serial GPS device hooked up on Serial 2.1Hz NMEA data.
TinyGPS gps;
  Serial.begin(115200);           //set serial monitor Port Baud rate
  Serial1.begin(9600);            //set GPS Port One Baud rate.
  Serial2.begin(9600);            //set GPS Port Two Baud rate.
  Serial.print("GPS Test: Two Port Data");
  bool newDataOne = false;
  bool newDataTwo = false;
  unsigned long chars;
  // For 1000ms we parse GPS data and report some key values
  for (unsigned long start = millis(); millis() - start < 1000;)
    while (Serial1.available())    // Port One Data available
      char c = Serial1.read();
      if (gps.encode(c))           // Did a new valid sentence come in?
        newDataOne = true;
  if (newDataOne)                  // If Port One Data available
    float flata, flona;
    gps.f_get_position(&flata, &flona);   // Get LAT, LON data
    Serial.print(" GPS 1 LAT="); Serial.print(flata, 8);
    Serial.print(" LON="); Serial.print(flona, 8);
    Serial.print(" SAT="); Serial.print(gps.satellites());
    Serial.print(" HDOP="); Serial.print(gps.hdop());
    Serial.print(" ALT="); Serial.print(gps.f_altitude());
    Serial.print(" COG="); Serial.print(gps.f_course());
    Serial.print(" Speed kmph="); Serial.print(gps.f_speed_kmph());
    while (Serial2.available())      // Port Two Data available
      char d = Serial2.read();
      if (gps.encode(d))             // Did a new valid sentence come in?
        newDataTwo = true;
  if (newDataTwo)                    // If Port Two Data available
    float flatb, flonb;
    gps.f_get_position(&flatb, &flonb);    // Get LAT, LON data
    Serial.print(" GPS 2 LAT="); Serial.print(flatb, 8);
    Serial.print(" LON="); Serial.print(flonb, 8);
    Serial.print(" LAT Diff="); Serial.print(flatb-51, 8);    //Perform a calculation on the second set of LAT data
    Serial.print(" LON Diff="); Serial.print(flonb-1, 8);    //Perform a calculation on the second set of LON data
So, whilst this works, its a bit clunky in the sense that it is synchronous and the loop has a 1 second timer on it. If I up the data rate from the GPS engine (UBlox - can go to 4Hz), how can I speed up the routine to handle the faster data rate?
Secondly, I wanted to perform a calculation between the first and second data, for example the distance between the LAT of data A and data B, but because the data is contained within their own loops, it doesn't work. In my example above I have performed data within the second loop (B) which does work just as a check. So, how can I perform the calculation?
Any help much appreciated ! Thanks.
Remove the "for" loop around the serial read out. The GPS library tells you when it's finished reading a complete record so there's no need to loop for one second.
Use two instances of TinyGPS or save the corresponding values when you print them out.
Thanks for your suggestions Pylon. I've ended up using the newer TinyGPS+ library. I've found that a lot easier to use and includes some helpful functions which means that the code is very straight forward.
GPSJay,
Could you please post your dual GPS code using TinyGPS+ library? Did you use software serial or did you stick to hardware serial? I'm not exactly sure I know the implications of either at this point.
Thanks,
Taylor
