2 sketch and one Arduino
Hi, I have a noob question.
I have this sketch, that allow me to turn on/off a led thru Telegram:
    Control an LED strip using Inline Keyboard on Telegram
    By Brian Lough
    YouTube: https://www.youtube.com/brianlough
    Tindie: https://www.tindie.com/stores/brianlough/
    Twitter: https://twitter.com/witnessmenow
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
// Library for interacting with the Telegram API
// Search for "Telegegram" in the Library manager and install
// The universal Telegram library
// https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot
#include <ArduinoJson.h>
// Library used for parsing Json from the API responses
// NOTE: There is a breaking change in the 6.x.x version,
// install the 5.x.x version instead
// Search for "Arduino Json" in the Arduino Library manager
// https://github.com/bblanchon/ArduinoJson
//------- Replace the following! ------
char ssid[] = "xxxxxxx";         // your network SSID (name)
char password[] = "xxxxxxxx"; // your network password
#define TELEGRAM_BOT_TOKEN "xxxxxxx"
#include "pitches.h"
// This is the Wifi client that supports HTTPS
WiFiClientSecure client;
UniversalTelegramBot bot(TELEGRAM_BOT_TOKEN, client);
#define LED_PIN 2 // Same as D4 for Wemos
int delayBetweenChecks = 1000;
unsigned long lastTimeChecked;   //last time messages' scan has been done
unsigned long lightTimerExpires;
boolean lightTimerActive = false;
  // Set WiFi to station mode and disconnect from an AP if it was Previously connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  pinMode(2, OUTPUT);
  digitalWrite(2, LOW);
  // attempt to connect to Wifi network:
  Serial.print("Connecting Wifi: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("IP address: ");
  // Only required on 2.5 Beta
  client.setInsecure();
  // longPoll keeps the request to Telegram open for the given amount of seconds if there are no messages
  // This hugely improves response time of the bot, but is only really suitable for projects
  // where the the initial interaction comes from Telegram as the requests will block the loop for
  // the length of the long poll
  bot.longPoll = 60;
void handleNewMessages(int numNewMessages) {
  for (int i = 0; i < numNewMessages; i++) {
    // If the type is a "callback_query", a inline keyboard button was pressed
    if (bot.messages[i].type ==  F("callback_query")) {
      String text = bot.messages[i].text;
      Serial.print("Call back button pressed with text: ");
      Serial.println(text);
      if (text == F("ON")) {
        digitalWrite(LED_PIN, HIGH);
      } else if (text == F("OFF")) {
        digitalWrite(LED_PIN, LOW);
      } else if (text.startsWith("TIME")) {
        text.replace("TIME", "");
        int timeRequested = text.toInt();
        lightTimerActive = true;
        lightTimerExpires = millis() + (timeRequested * 1000 * 60);
      String chat_id = String(bot.messages[i].chat_id);
      if (text == F("/options")) {
        // Keyboard Json is an array of arrays.
        // The size of the main array is how many row options the keyboard has
        // The size of the sub arrays is how many coloums that row has
        // "The Text" property is what shows up in the keyboard
        // The "callback_data" property is the text that gets sent when pressed
        String keyboardJson = F("[[{ \"text\" : \"ON\", \"callback_data\" : \"ON\" },{ \"text\" : \"OFF\", \"callback_data\" : \"OFF\" }],");
        keyboardJson += F("[{ \"text\" : \"10 Mins\", \"callback_data\" : \"TIME10\" }, { \"text\" : \"20 Mins\", \"callback_data\" : \"TIME20\" }, { \"text\" : \"30 Mins\", \"callback_data\" : \"TIME30\" }]]");
        bot.sendMessageWithInlineKeyboard(chat_id, "Sadbhs Stars", "", keyboardJson);
      // When a user first uses a bot they will send a "/start" command
      // So this is a good place to let the users know what commands are available
      if (text == F("/start")) {
        bot.sendMessage(chat_id, "/options : returns the inline keyboard\n", "Markdown");
  if (millis() > lastTimeChecked + delayBetweenChecks)  {
    // getUpdates returns 1 if there is a new message from Telegram
    int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
    if (numNewMessages) {
      Serial.println("got response");
      handleNewMessages(numNewMessages);
    lastTimeChecked = millis();
    if (lightTimerActive && millis() > lightTimerExpires) {
Ant then, I have this Imperial March + Buzzer sketch:
const int c = 261;
const int d = 294;
const int e = 329;
const int f = 349;
const int g = 391;
const int gS = 415;
const int a = 440;
const int aS = 455;
const int b = 466;
const int cH = 523;
const int cSH = 554;
const int dH = 587;
const int dSH = 622;
const int eH = 659;
const int fH = 698;
const int fSH = 740;
const int gH = 784;
const int gSH = 830;
const int aH = 880;
const int buzzerPin = 8;
const int ledPin1 = 12;
const int ledPin2 = 13;
//const int play = 3;
int counter = 0;
  //Setup pin modes
  pinMode(buzzerPin, OUTPUT);
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
//  pinMode(play, INPUT);
// if (in == HIGH) {
  //Play first section
  firstSection();
  //Play second section
  secondSection();
  //Variant 1
  beep(f, 250);
  beep(gS, 500);
  beep(f, 350);
  beep(a, 125);
  beep(cH, 500);
  beep(a, 375);
  beep(cH, 125);
  beep(eH, 650);
  //Repeat second section
  secondSection();
  //Variant 2
  beep(f, 250);
  beep(gS, 500);
  beep(f, 375);
  beep(cH, 125);
  beep(a, 500);
  beep(f, 375);
  beep(cH, 125);
  beep(a, 650);
  delay(650);
void beep(int note, int duration)
  //Play tone on buzzerPin
  tone(buzzerPin, note, duration);
  //Play different LED depending on value of 'counter'
  if(counter % 2 == 0)
    digitalWrite(ledPin1, HIGH);
    delay(duration);
    digitalWrite(ledPin1, LOW);
  }else
    digitalWrite(ledPin2, HIGH);
    delay(duration);
    digitalWrite(ledPin2, LOW);
  //Stop tone on buzzerPin
  noTone(buzzerPin);
  delay(50);
  //Increment counter
  counter++;
void firstSection()
  beep(a, 500);
  beep(a, 500);
  beep(a, 500);
  beep(f, 350);
  beep(cH, 150);
  beep(a, 500);
  beep(f, 350);
  beep(cH, 150);
  beep(a, 650);
  beep(eH, 500);
  beep(eH, 500);
  beep(eH, 500);
  beep(fH, 350);
  beep(cH, 150);
  beep(gS, 500);
  beep(f, 350);
  beep(cH, 150);
  beep(a, 650);
void secondSection()
  beep(aH, 500);
  beep(a, 300);
  beep(a, 150);
  beep(aH, 500);
  beep(gSH, 325);
  beep(gH, 175);
  beep(fSH, 125);
  beep(fH, 125);
  beep(fSH, 250);
  delay(325);
  beep(aS, 250);
  beep(dSH, 500);
  beep(dH, 325);
  beep(cSH, 175);
  beep(cH, 125);
  beep(b, 125);
  beep(cH, 250);
  delay(350);
What's the proper way to mix these two in one, so when the led goes HIGH the Buzzer starts playing it?
I'm really confused.
I try putting the code like this, but doesn't works:
    By Brian Lough
char ssid[] = "xxxxx";         // your network SSID (name)
char password[] = "xxxx"; // your network password
#define TELEGRAM_BOT_TOKEN "xxxx:xxxx"
 * Star Wars Theme in a Buzzer
//This are the notes
const int c = 261;
const int d = 294;
const int e = 329;
const int f = 349;
const int g = 391;
const int gS = 415;
const int a = 440;
const int aS = 455;
const int b = 466;
const int cH = 523;
const int dH = 587;
const int eH = 659;
const int fH = 698;
const int gH = 784;
const int aH = 880;
const int buzzerPin = 3;
int counter = 0;
  //Setup pin modes for star wars buzzer
  digitalWrite(buzzerPin, LOW);
  WiFi.disconnect();
  delay(100);
  pinMode(2, OUTPUT);
    Serial.print(".");
  Serial.println("");
  bot.longPoll = 60;
  noTone(buzzerPin);
  delay(50);
  //Increment counter
  counter++;
void firstSection()
  beep(a, 500);
  beep(a, 500);
  beep(a, 500);
  beep(f, 350);
  beep(cH, 150);
  beep(a, 500);
  beep(f, 350);
  beep(cH, 150);
  beep(a, 650);
  beep(eH, 500);
  beep(eH, 500);
  beep(eH, 500);
  beep(fH, 350);
  beep(cH, 150);
  beep(gS, 500);
  beep(f, 350);
  beep(cH, 150);
  beep(a, 650);
  beep(aH, 500);
  beep(a, 300);
  beep(a, 150);
  beep(aH, 500);
  beep(gSH, 325);
  beep(gH, 175);
  beep(fSH, 125);
  beep(fH, 125);
  beep(fSH, 250);
  delay(325);
  beep(aS, 250);
  beep(dSH, 500);
  beep(dH, 325);
  beep(cSH, 175);
  beep(cH, 125);
  beep(b, 125);
  beep(cH, 250);
  delay(350);
         firstSection();
  secondSection();
  //Variant 1
  beep(f, 250);
  beep(gS, 500);
  beep(f, 350);
  beep(a, 125);
  beep(cH, 500);
  beep(a, 375);
  beep(cH, 125);
  beep(eH, 650);
  secondSection();
  //Variant 2
  beep(f, 250);
  beep(gS, 500);
  beep(f, 375);
  beep(cH, 125);
  beep(a, 500);
  beep(f, 375);
  beep(cH, 125);
  beep(a, 650);
  delay(650);
You seem to have private connection details in your code - you should edit your Posts and remove them and replace them with XXX
When using millis() you should always use subtraction to prevent problems when millis() rolls over. Like this
if (millis() - lastTimeChecked >= delayBetweenChecks)  {
You say " but doesn't works" which gives us no information with which to help you. You need to tell us what the program actually does and what you want it to do that is different.
I am not familiar with the UniversalTelegramBot.h library so if that is where the problem lies I doubt if I will be able to help.
I suspect you should remove all the delay()s from your program and replace them with non-blocking timing using millis()
...R
Cheez, I forget about the data, thanks for that.
The program allows you to turn on and off leds using telegram bot.
I just want to add a buzzer sound sequence when led get on, but as you say I'll review the code again. Thanks.
rafael1138:
Perhaps, but I presume your question arises because it is not doing exactly what you want it to do and you have not told us what it actually does.
If you need more help please provide that information with the latest version of your program.
...R
