2 softserials - not working properly
I have a arduino MEGA with a bluetooth module connected to another arduino UNO
I have 2 softserials:
one for sending commands to another arduino and wait for a reply if the command is executed
the other one is for the bluetooth connection, to listen for a command (or in the future sending some data). But when the first command is send through softserial 1 and is being executed, I can send a 1 or 0 though bluetooth, but at the end of the execution (softserial one) the code stops, and I can only receive something on my softserial 2. it does not read a new command from my file on the SD card…
code:
// CONSTANTS
#define BAUD (57600) // How fast is the Arduino talking SERIAL MONITOR (just for us, humans)?
#define BAUD2 (4800) // How fast is the Arduino talking SOFTSERIAL
#define BAUD3 (9600) // How fast is the Arduino talking SOFTSERIAL for BlueTooth connection
// INCLUDES
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>//https://www.arduino.cc/en/Tutorial/TwoPortReceive
// GLOBALS
// WORKING VALUES
char inputString [100];
char inputChar;
boolean ResetFile = true;
long randNumber;
String filename;
int stringIndex = 0; // String stringIndexing int;
int lineIndex = 1;
int Received = 0;
int LEDstate = 0;
// SOFTWARE SERIAL #1: RX = digital pin 10, TX = digital pin 11
SoftwareSerial mySerial(11, 12); // RX, TX
// SOFTWARE SERIAL #2: RX = digital pin 10, TX = digital pin 13
SoftwareSerial mySerialBT(10, 13); // RX, TX
//CONNECTIONS
File myFile; // instance of a file
void setup(){
  Serial.begin(BAUD);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("ARDUINO MEGA - SD SHIELD");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(BAUD2);
  while (!mySerial) {
mySerialBT.begin(BAUD3);
 while (!mySerialBT) {
  // if analog input pin 0 is unconnected, random analog
  // noise will cause the call to randomSeed() to generate
  // different seed numbers each time the sketch runs.
  // randomSeed() will then shuffle the random function.
  randomSeed(analogRead(0)); //NEEDED FOR THE RANDOM FUNCTION
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(SS, OUTPUT); //MEGA: SS
  //ONLY FOR THE UNO
  pinMode(53, OUTPUT);  //MEGA: 53, UNO 10
  digitalWrite(53, HIGH); //MEGA: 53, UNO 10
  // see if the card is present and can be initialized:
  if (!SD.begin(4)){
    Serial.println("Initialization failed: card failed, or not present");
    // don't do anything more:
    while (1) ;
  Serial.println("Initialization done.");
  //OPEN A RANDOM FILE FROM THE SD CARD
  OpenFile();
void OpenFile() {
  if (ResetFile == true){
    Serial.println("Reset Drawing");
    filename = "TEST.txt"; //reset the drawing
    ResetFile = false;
  }else{
    //Choose a random filenumber
    randNumber = random(1, 5);  //CHOOSE RANDMLY A FILENUMBER BETWEEN 1 AND 4
    filename = "TEST" + String(randNumber);
    filename = filename + ".txt";
    ResetFile = true;
  // Open up the file we're going to log to!
  myFile = SD.open(filename);
  if (! myFile){
    Serial.print("error opening File: ");
    Serial.println(filename);
    Serial.println("No such file in directory");
    // Wait forever since we cant write data
    while (1) ;
    Serial.print("....Reading ");
    Serial.print(filename);
    Serial.println(":");
    delay(100);
 inputChar = myFile.read(); // Gets one byte from serial buffer
  if (inputChar != '\n')
      { // define breaking char here
        if (inputChar == 'Q')  //end of the file
           Serial.println("---END OF FILE---");
            myFile.close();
            //OPEN A NEW RANDOM FILE OR RESET FILE
            lineIndex=1;
            OpenFile();
            inputString[stringIndex] = inputChar; // Store it
            stringIndex++; // Increment where to write next
        Serial.print("line ");
        Serial.print(lineIndex);
        Serial.print(": "); // shows that the program is cycling, for debugging only
        Serial.println(inputString);
      mySerial.write(inputString);
        stringIndex = 0; // clear the value for the next line
        lineIndex++;
        memset(inputString, 0, sizeof(inputString));
     //Wait until the other UNO repsonse with "1" //or "0" (1=ok, 0=nok)
     while (mySerial.available() == 0) {
//////////////////BLUETOOTH///////////////////////////
 while (mySerialBT.available() > 0) {
    Received = mySerialBT.read();
if (LEDstate == 0 && Received == '1')
    Serial.println("LED on");
    LEDstate=1;
if (LEDstate ==1 && Received == '0')
    Serial.println("LED off");
    LEDstate=0;
                char iByte = mySerial.read();
              if (iByte =='1') {
                  Serial.println("Command executed, next line please..");
Don't use SoftwareSerial, it's a hack that eats up all of your resources, is slow and unreliable.
Your Arduino MEGA has multiple hardware UARTs. Use those instead.
Pieter
A Mega has 3 additional hardware serial ports; a quick view at your code does not seem to show a reason why you can't use those instead software serial.
Also, why e.g.
It clearly states that that is only required for native USB and SoftwareSerial is definitely not native USB.
Problem solved,
thanks anyway (and thanks to bring the 2 other 'normal' serials of a MEGA to my attention)
