2 stepper motors running at the same time ?library
i am using 2 easydrivers( using 2 pins, one for direction and the other for the number of steps), and i am trying to build a library which allow you to make the motor run at the same time with different speed, but i
couldn’t manage how to ignore the delay() between 2 steps in the main loop() ?? for now only one stepper is moving and then the other one start. it’s my first library.
a little help would be more than welcome.
here is the library
#ifndef Mot_h
#define Mot_h
#include "WProgram.h"
class Mot
public:
    Mot(int pindir, int pinstep);
   void move(int step,int del, boolean dir);//del=delay();
  private:
  int dirpin;
    int steppin;
  int step;
int del;
 boolean dir;
#endif
#include "Mot.h"
Mot::Mot(int pindir, int pinstep)
  pinMode(pindir, OUTPUT);
  pinMode(pinstep, OUTPUT);
dirpin = pindir;
steppin=pinstep;
void Mot::move(int step,int del, boolean dir)
int i;
if(dir==false){
digitalWrite(dirpin,HIGH);
for(i=0;i<step;i++){
  digitalWrite(steppin, HIGH);
delayMicroseconds(del);
  digitalWrite(steppin, LOW);
if(dir==true){
digitalWrite(dirpin,LOW);
here’s the arduino code
#include <Mot.h>
Mot motx=Mot(2,3);
Mot moty=Mot(5,6);
int deltaxneg=0;
int deltayneg;
int mess [15];
int deltax=0;
int deltay=0;
int delx=0;
int dely=0;
int dess=0;
boolean dirx;
boolean diry;
int pindir=2;
int pinstep=3;
 Serial.begin(115200); // Initiate Serial Communication
pinMode(pindir,OUTPUT);
pinMode(pinstep,OUTPUT);
establishContact();
int i;
int j;
int r;
  if ( Serial.available() ) {
   for (i=0;i<15;i++){
   mess[i]=0;
 mess [i]=Serial.read()-48;
delayMicroseconds(100);
   deltax=mess[0]*100+mess[1]*10+ mess[2] ;
   deltay=mess[3]*100+mess[4]*10+ mess[5] ;
   delx=mess[6]*1000+mess[7]*100+ mess[8]*10+mess[9]  ;
   dely=mess[10]*1000+mess[11]*100+ mess[12]*10+mess[13] ;
   dess=mess[14];
    if((deltay>0)&&(deltay<500)){
      diry=true;
      moty.move(deltay*5,dely,diry);
   if((deltay>500)&&(deltay<1000)){
     diry=false;
     deltayneg=deltay-500;
     moty.move(deltayneg*5,dely,diry);
      if((deltax>0)&&(deltax<500)){
  dirx=true;
     motx.move(deltax*5,delx,dirx);
   if((deltax>500)&&(deltax<1000)){
     dirx=false;
     deltaxneg=deltax-500;
   motx.move(deltaxneg*5,delx,dirx);
Serial.flush();
 Serial.print('A', BYTE);
void establishContact() {
  while (Serial.available() <= 0) {
    Serial.print('A', BYTE);   // send a capital A
    delay(300);
I didn't have a chance to look at your code too closely, but you could probably use the millis() function instead of delays.
