Total new member and beginner here, Since I was able to get a real CNC router, 1200 x 1200
I had parts from my DIY , this inspired me to try to learn Arduino, and I have built a few of the demos, and the stepper motor tutorial with the one that comes in the kit, but now I have hooked up the big ones
I want to utilize Arduino and write the code myself if its possible
I used the accelstepper library code to control speed, 1 stepper and 1 pot.
this was fun but just 1 part of what I want.
I used the tutorial example code created a prototype that will turn stepper x revs forward x revs reverse. I see how the angle can be changed with code , can i change with a pot?
So is this even possible to do with the UNO, and this controller ? HY-DIV268N-5A
here is what i am trying to accomplish,
motor 1 rotates X degrees forward X degrees reverse
motor 1 can rotate N rpm
X is controlled with a potentiometer 1
N is controlled with a potentiometer 2
motor 2 rotates X degrees forward X degrees reverse
motor 2 can rotate N rpm
X is controlled with a potentiometer 3
N is controlled with a potentiometer 4
let me know if this is possilbe with sketch or am i way off base?
thanks
dave
![IMG_3867[2034].jpg](https://europe1.discourse-cdn.com/arduino/original/3X/1/4/14ad8e9a8c17820475f6da24c613dc4123447cb3.jpg)
