Hi!
I have 2 buttons and 4 leds. When I press button A it changes in sequence 3 cases (turns on and off each LED for each case respectively). Each case does a function. The first one does AlarmAction with alarm function and it is working. The second function (case) does a calculation what day (even-odd) we have and if it is odd will do the AlarmAction but it is not working. The third function does nothing. The second button whenever it is pressed (second led)does the AlarmAction (second led) and it is working.
#include <math.h>
#include <Time.h>
#include <TimeAlarms.h>
#include <TimeLib.h>
#include <DS1302RTC.h>
#define A 33//orange
#define B 35//blue
#define C 37//grey
#define D 39//green
#define E 41//yellow
#define F 43//red
#define G 45//brown
#define ON LOW
#define OFF HIGH
const int inbutton1 = 2;
const int inbutton2 = 3;
int button2state;
int lastbutton1state = HIGH;
int lastbutton2state = HIGH;
int actual;
int val;
int val2;// variable for reading the pin status
// variable for reading the delayed status
int button1state; // variable to hold the button state
int Mode = 0;
unsigned long startTime;
unsigned long elapsedTime;
const int ledPin1 = 7;
const int ledPin2 = 8;
const int ledPin3 = 9;
const int ledPin4 = 10;
// variables will change:
// variable for reading the pushbutton status
unsigned long previousMillis = 0;
const long interval = 1000;
unsigned long noOfSeconds;
int noOfWholeDays;
int todayIsDay;
bool todayIsOdd;
DS1302RTC RTC(27, 29, 31);//WHITE - BROWN - ORANGE - BLACK GND - RED POSITIVE
//boolean debug = 1; // 1 = Print Serial Enabled / 0 = disabled
// SETUP
void setup () {
digitalWrite(A, HIGH);
digitalWrite(B, HIGH);
digitalWrite(C, HIGH);
digitalWrite(D, HIGH);
digitalWrite(E, HIGH);
digitalWrite(F, HIGH);
digitalWrite(G, HIGH);
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(E, OUTPUT);
pinMode(F, OUTPUT);
pinMode(G, OUTPUT);
button1state = digitalRead(inbutton1);
button2state = digitalRead(inbutton2);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(inbutton1, INPUT);
pinMode(inbutton2, INPUT);
//if (debug)
Serial.print("Initial Mode: ");
Serial.print("Setup Complete\n");
Serial.print("RTC activated");
if (RTC.haltRTC())
Serial.print("Clock stopped!");
Serial.print("Clock working");
Serial.print("RTC Sync");
setSyncProvider(RTC.get); // the function to get the time from the RTC
if(timeStatus() == timeSet)
Serial.print(" Ok!");
Serial.print(" FAIL!");
//setTime(21,37,0,9,20,18); // set time to Saturday 8:29:00am Jan 1 2011
// Main Loop
if (button2state == HIGH) {
AlarmAction ();
// turn LED off:
digitalWrite(ledPin1, LOW);
val = digitalRead(inbutton1); // read input value and store it in val
delay(10); // 10 milliseconds is a good amount of time
val2 = digitalRead(inbutton1); // read the input again to check for bounces
if (val == val2) { // make sure we got 2 consistant readings!
if (val != button1state) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
if (Mode == 0) {
Mode = 1;
if (Mode == 1) {
Mode = 2;
if (Mode == 2) {
Mode = 3;
if (Mode == 3) {
Mode = 0;
{ if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
digitalClockDisplay();
// if the LED is off turn it on and vice-versa:
if (button1state == HIGH && button1state != lastbutton1state)
if(actual == 3) actual = 0;
else actual++;
lastbutton1state = button1state;
switch(actual)
case 0:
showState();
case 1:
WhatDay ();
case 2:
button1state = val; // save the new state in our variable
// Now do whatever the lightMode indicates
if (Mode == 0) { // all-off
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
if (Mode == 1) {
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, HIGH);
if (Mode == 2) {
digitalWrite(ledPin4, HIGH);
// Subroutine
void showState() {
//if (debug)
Serial.println("Mode:EVERYDAY");
Alarm.delay(50); // wait one second between clock display
Alarm.alarmOnce(21,40,0, AlarmAction); // every day
void WhatDay () {
Serial.println("Mode:ODD-EVEN");
noOfSeconds = RTC.get();
noOfWholeDays = noOfSeconds / 86400;
todayIsDay = noOfWholeDays + 1;
if (todayIsDay % 2 == 0)
todayIsOdd = false;
todayIsOdd = true;
if (todayIsOdd)
Serial.print("Today ODD day");
Alarm.alarmOnce(21,50,0,AlarmAction);
Serial.print("Today EVEN day");
delay (25);
void AlarmAction () {
// functions to be called when an alarm triggers:
Serial.print("POTISMA");
digitalWrite(ledPin1, HIGH);
/*one();
digitalWrite(52, LOW); //RELAY 1 ON
delay(1000L*60L*1L); //wait 4 min
two();
digitalWrite(52, HIGH); //RELAY 1 OFF
digitalWrite(50, LOW); //RELAY 2 ON
three();
digitalWrite(50, HIGH); //RELAY 2 OFF
digitalWrite(48, LOW); //RELAY 3 ON
delay(1000L*60L*1L); //wait 5 min
four();
digitalWrite(48, HIGH); //RELAY 3 OFF
digitalWrite(46, LOW); //RELAY 4 ON
five();
digitalWrite(46, HIGH); //RELAY 4 OFF
digitalWrite(44, LOW); //RELAY 5 ON
six();
digitalWrite(44, HIGH); //RELAY 5 OFF
digitalWrite(42, LOW); //RELAY 6 ON
delay(1000L*60L*1L); //wait 5 min*/
delay(5000); //wait 5 min
void digitalClockDisplay()
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print("-");
Serial.print(day());
Serial.print("/");
Serial.print(month());
Serial.print("/");
Serial.print(year());
delay(10);
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
What I want to do at the first case is the same thing the same time everyday. In second case I want to do it every second day the same time. In third case do nothing.
The problem is at the second function. The alarm function does not work.
Thanks in advance!
