Hello.
So I am trying to build RC car using Arduino UNO. On the picture below you can see my electric sheme. The problem I have is that when I power up the circuit SERVO motor is working OK (I move servo by rotating potenciometer), but when I try to move DC motor by pressing buttons it doesn't work (there is a red light on L298N modul but I think that is normal since it is on even when the modul is working OK).
I tried the system where I use only L298N, DC motor and 4 PUSH-BUTTONS and everything works as it should, but as soon as I add Servo in the program and in the circet, the Servo is working OK but L298N, DC motor and PUSH-BUTTONS are not responding.
From what I read, L298N needs 2V to operate and the rest goes to motors so in my case the motor should get 5V which is enough.
Doese anyone have any idea why would this happend?
Thank you for your help.
Electric scheme:
Program:
#include <Servo.h>
Servo myservo;
int a=0;
int b=0;
int c=0;
#define enA 10
#define in1 4
#define in2 5
int motorSpeedA = 0;
int gear = 0;
myservo.attach(9);
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(1, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
a=analogRead(A0);
int forward = digitalRead(1);
int backward = digitalRead(3);
int gear1 = digitalRead(6);
int gear2 = digitalRead( 8 );
if(a != b){
b=a;
c=map(b, 0, 1023, 55, 115);
if(gear1 == 0){
gear = 110;
if(gear2 == 0){
gear = 210;
if(forward == 0){
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
motorSpeedA = gear;
else if(backward == 0){
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
motorSpeedA = 110;
else{
motorSpeedA = 0;
analogWrite(enA, motorSpeedA);
myservo.write(c);
