hello,
could someone please help me out, i want to connect two thermistors to my arduino for 2 different measurements
i have 2 10k ohm thermistors and 2 10k ohm resistors. i'm still learning C, the only problem i have is the coding.
i already got the board working with one thermistor that works great using this code:
librarie:
Thermistor.h
#ifndef Thermistor_h
#define Thermistor_h
#include "Arduino.h"
#include "math.h"
class Thermistor {
public:
Thermistor(int pin);
double getTemp();
private:
int _pin;
#endif
thermistor.cpp
#include "Thermistor.h"
Thermistor::Thermistor(int pin) {
_pin = pin;
double Thermistor::getTemp() {
// Inputs ADC Value from Thermistor and outputs Temperature in Celsius
int RawADC = analogRead(_pin);
long Resistance;
double Temp;
// Assuming a 10k Thermistor. Calculation is actually: Resistance = (1024/ADC)
Resistance=((10240000/RawADC) - 10000);
/* Utilizes the Steinhart-Hart Thermistor Equation: */
/* Temperature in Kelvin = 1 / {A + B[ln(R)] + C[ln(R)]^3} */
/* where A = 0.001129148, B = 0.000234125 and C = 8.76741E-08 */
Temp = log(Resistance);
Temp = 1 / (0.001129148 + (0.000234125 * Temp) + (0.0000000876741 * Temp * Temp * Temp));
Temp = Temp - 273.15; // Convert Kelvin to Celsius
/* - TESTING OUTPUT - remove lines with * to get serial print of data
Serial.print("ADC: "); Serial.print(RawADC); Serial.print("/1024"); // Print out RAW ADC Number
Serial.print(", Volts: "); printDouble(((RawADC*4.860)/1024.0),3); // 4.860 volts is what my USB Port outputs.
Serial.print(", Resistance: "); Serial.print(Resistance); Serial.print("ohms");
// Uncomment this line for the function to return Fahrenheit instead.
//Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert to Fahrenheit
return Temp; // Return the Temperature
main code:
#include <Thermistor.h>
Thermistor temp(0);
int temperature = temp.getTemp();
Serial.print("Temperatura no Sensor eh: ");
Serial.print(temperature);
Serial.println("*C");
now i want to use the second thermistor as well, so could please someone help me out and get my second thermistor to work too. that would be great!
Danny
Moderator: added a lot of code tags => # button above smileys! please use them
