2 variables of the same type, 1 private in library, the other in the sketch
Hi all,
I'm pretty new to C++ and I need help for some very basic info ...
in my library I have a private variable declared as
int pin = 10;
that gets its value set through ctor injection, so I'll have another
int pin = 12;
in my sketch to set the desired value.
The compiler tells me
multiple definition of [...] first defined here
what is the problem?
in the library I did
private:
  	int pin;
shouldn't it be hidden to external code?
thank you for your help! =)
You need to post a complete example which demonstrates the problem, not just snippets of code.
in my project I have a private variable declared as
Why do you have that? You have a private member named pin. Why are you creating another variable named pin?
