The "body" is made out of some cheap plastic-pvc-foam. And glued together. Also had to limit movement of the servos, cause 0-180 brakes it.
Any thoughts?
Any thoughts?
Very cool. Now fit wheels to it ![]()
heh thats pretty kool ![]()
Do you have a sketch you could post showing the two servo program, on your wed site I only found the single servo controller.
Lefty
Can you post more information?
You use an compensator function?
Lefty
Well, this one uses almost exactly the same code, just add another IF statement, for up & down decision.
I can post the code for the 2-way later if anyone want it. But as said before it's just the 1-way x2 ![]()
Code:
