2-wire ABS sensor, trying to read reluctor using interrupts. ZERO luck.
No matter what computer and where I try to edit it from, I get an error and get locked out of the website. I was trying to fit the IMG tags on my last post, but I end up having to reset my router just go to get back here once I had that Edit button.
Anyway, I apparently have a VR signal and need to do some signal conditioning.
Maxim makes some very good stuff I can get from Digi-key.
The 2 recommended are the MAX9924 and MAX9926.
My understanding is that the 9924 is the single channel version, and the 9926 is the dual channel version.
Since I need to read 2 of these sensors, I assume the 9926 will accomplish what it would take 2 of the MAX9924 to do?
