Hello sir,
I need to store 20,000 finger print templates in finger print sensor..
how can i achieve 20k finger prints enrollment and verification using arduino.
I searched some finger print sensors specifications..But those storage capacities are very less
See below
WishioT Green Light Optical Fingerprint Reader Sensor Module for Arduino Mega2560 UNO R3
Note:
There are basically two requirements for using the optical fingerprint sensor. First is you'll need to enroll fingerprints - that means assigning ID #'s to each print so you can query them later. Once you've enrolled all your prints, you can easily 'search' the sensor, asking it to identify which ID (if any) is currently being photographed.
You can enroll by using the windows software (easiest and neat because it shows you the photograph of the print) or with the Arduino sketch (good for when you don't have a windows machine handy or for on-the-road enrolling) Connection
pin #2 is IN from sensor (GREEN wire)
pin #3 is OUT from arduino (WHITE wire)
5V connect sensor (Red wire)
GND connect sensor (Black wire)
NOTE: Please use arduino IDE 1.6.6
Features:
Make adding fingerprint detection and verification super simple.
Typically used in safes - there's a high powered DSP chip that does the image rendering, calculation, feature-finding and searching.
Connect to any microcontroller or system with TTL serial, and send packets of data to take photos, detect prints, hash and search.
You can also enroll new fingers directly - up to 162 finger prints can be stored in the onboard FLASH memory.
There's a red LED in the lens that lights up during a photo so you know it is working.
Specifications:
Supply voltage: DC 3.8-7.0V
Operating Current: <65mA
Peak current: <95mA
Fingerprint image time: <1.0 seconds
Window area: 14.5*19.4 mm
Signature File: 256 bytes
Template files: 512 bytes
Storage capacity: 1000
Package includes:
1 x Fingerprint Recognition Module
One more optical finger print sensor is given below
Supply voltage: 3.6 - 6.0VDC
Operating current: 120mA max
Peak current: 150mA max
Fingerprint imaging time: <1.0 seconds
Window area: 14mm x 18mm
Signature file: 256 bytes
Template file: 512 bytes
Storage capacity: 162 templates
Safety ratings (1-5 low to high safety)
False Acceptance Rate: <0.001% (Security level 3)
False Reject Rate: <1.0% (Security level 3)
Interface: TTL Serial
Baud rate: 9600, 19200, 28800, 38400, 57600 (default is 57600)
Working temperature rating: -20C to +50C
Working humidy: 40%-85% RH
Full Dimensions: 56 x 20 x 21.5mm
Exposed Dimensions (when placed in box): 21mm x 21mm x 21mm triangular
Weight: 20 grams
If i want to store those data in SD card through micro sd card adapter ,how can i verify?(verification should be done by finger print sensor ..that image processing)..
Can u please give any solution for this problem??
