220 AC Led Dimmer Using Bluetooth and Potentiometer Problem
Hello Everyone!
I'm New in this forum. I need a bit of help with my project.
I want to dim a 220 ac dimmable led using either Bluetooth app(made with MIT App Inventor 2) and potentiometer.
I can dim the led using either method but, I need to re-upload the sketch of the either the Bluetooth or potentiometer.
Here is the flow diagram:
Here the code I made so far:
const int analogInPin = A0;             // Analog input pin that the potentiometer is attached to.
const int ledPin = 9;                   // Needs to be a pin supporting PWM.
int value = -1;
int analogValue = 0;
int sensorValue = -1;                   // value read from the pot
String inputString = "" ;
char junk;
  pinMode(ledPin, OUTPUT);
  if (Serial.available())
    while (Serial.available())             // Read while there is data in the buffer
      char c = Serial.read();              //read the input
      inputString += c;                    //make a string of the characters coming on serial
      junk = Serial.read();                // clear the serial buffer
    if (inputString == "a")
      value = Serial.read();
        if (value >= 0)                     // If we have meaningful data
          Serial.println(value);            // Debug - double check it make sense
          analogWrite(ledPin, value);       // set PWM for LED brightness
          value = -1;
    else if (inputString != "a")
      sensorValue = analogRead(analogInPin);              // read the analog in value:
      analogValue = map(sensorValue, 0, 1023, 0, 256);    // map it to the range of the analog out:
      analogWrite(ledPin, analogValue);                   // change the analog out value:
    inputString = "";
and here is the Android App code block:
So, the Arduino knows nothing about the potentiometer. How is the lightbulb supposed to know whether to take input from the Arduino or from the potentiometer?
You need to get the hardware straightened out before writing any code makes sense.
