24 Hour Clock + LCD 16x2 + RTC Module
Hello there!
Im alittle new here cause i just my arduino duemilanove and this is my first attempt to install a code to it
its not my code but found it on the web: Arduino Your Home & Environment: DS1307 Real Time Clock Working
Hardware:
  • Arduino Duemilanove
  • RTC clock module (Sparkfun)
  • 16x2 LCD Display
    (Exactly like the webpage)
So im trying to install this code but when im trying to verify it then it is telling me its wrong. so im here to get some help with my code.
_24_Hour_Clock.cpp: In function 'void setDateDs1307(byte, byte, byte, byte, byte, byte, byte)':
_24_Hour_Clock:60: error: call of overloaded 'write(int)' is ambiguous
C:\Users\Thomas\Desktop\arduino-1.0\libraries\Wire/Wire.h:55: note: candidates are: virtual size_t TwoWire::write(uint8_t)
C:\Users\Thomas\Desktop\arduino-1.0\hardware\arduino\cores\arduino/Print.h:49: note:                 size_t Print::write(const char*)
_24_Hour_Clock.cpp: In function 'void getDateDs1307(byte*, byte*, byte*, byte*, byte*, byte*, byte*)':
_24_Hour_Clock:82: error: call of overloaded 'write(int)' is ambiguous
This is the "Warning" / "Error"
Does anyone know how i can make it work or help me to the correct direction ?
Thanks in Advance
Have you tried to compile the code with 0.22 (pre 1.0) . There are some breaking changes between pre1.0 and 1.0 that could be the cause.
(testing)
0.22 compiles
1.0 doesn't.
qed.
I agree with Rob. Use arduino 0022. The arduino software has just recently been upgraded to 1.0 Lots of libraries that people wrote stopped working. Some of them have upgraded their libraries but not everyone.
BTW, I suggest you post this type of questions in programming or project guidance boards. You get more exposure with the right board.
Thanks Guys !
it worked with the v.0022 :slight_smile:
and i will post there insted next time :slight_smile:
