Hi there!
I worked on a little project where I trigger midi signals when the light hitting a ldr goes down certain threshold. I am working with 16 ldr´s, each one connected to an Analog Input in an Arduino Mega.
I would love to start using 24 ldr´s but still one Arduino Mega.
I understand that multiplexing is the way to go and I would like to try it.
Could anyone guide me a bit in the process?
thanks!
below is the code of my 16 ldr´s project.
unsigned char status;
#define midichannel 0;
int threshold = 700;
boolean Key1LastState01 = false;
boolean Key1LastState02 = false;
boolean Key1LastState03 = false;
boolean Key1LastState04 = false;
boolean Key1LastState05 = false;
boolean Key1LastState06 = false;
boolean Key1LastState07 = false;
boolean Key1LastState08 = false;
boolean Key1LastState09 = false;
boolean Key1LastState10 = false;
boolean Key1LastState11 = false;
boolean Key1LastState12 = false;
boolean Key1LastState13 = false;
boolean Key1LastState14 = false;
boolean Key1LastState15 = false;
boolean Key1LastState16 = false;
int sensorValue01;
int sensorValue02;
int sensorValue03;
int sensorValue04;
int sensorValue05;
int sensorValue06;
int sensorValue07;
int sensorValue08;
int sensorValue09;
int sensorValue10;
int sensorValue11;
int sensorValue12;
int sensorValue13;
int sensorValue14;
int sensorValue15;
int sensorValue16;
int sensornote01 = 55;
int sensornote02 = 54;
int sensornote03 = 53;
int sensornote04 = 52;
int sensornote05 = 51;
int sensornote06 = 50;
int sensornote07 = 49;
int sensornote08 = 48;
int sensornote09 = 47;
int sensornote10 = 46;
int sensornote11 = 45;
int sensornote12 = 44;
int sensornote13 = 43;
int sensornote14 = 42;
int sensornote15 = 41;
int sensornote16 = 40;
Serial.begin(57600);
sensorValue01 = analogRead(A0);
sensorValue02 = analogRead(A1);
sensorValue03 = analogRead(A2);
sensorValue04 = analogRead(A3);
sensorValue05 = analogRead(A4);
sensorValue06 = analogRead(A5);
sensorValue07 = analogRead(A6);
sensorValue08 = analogRead(A7);
sensorValue09 = analogRead(A8);
sensorValue10 = analogRead(A9);
sensorValue11 = analogRead(A10);
sensorValue12 = analogRead(A11);
sensorValue13 = analogRead(A12);
sensorValue14 = analogRead(A13);
sensorValue15 = analogRead(A14);
sensorValue16 = analogRead(A15);
//SENSOR 01---------------------------------------------------
if (sensorValue01 > threshold && Key1LastState01 == false) {
MIDI_TX(128,sensornote01,127);
Key1LastState01 = true;
else if (sensorValue01 < threshold && Key1LastState01 == true) {
MIDI_TX(144,sensornote01,127);
//SENSOR 02---------------------------------------------------
if (sensorValue02 > threshold && Key1LastState02 == false) {
MIDI_TX(128,sensornote02,127);
Key1LastState02 = true;
else if (sensorValue02 < threshold && Key1LastState02 == true) {
MIDI_TX(144,sensornote02,127);
//SENSOR 03---------------------------------------------------
if (sensorValue03 > threshold && Key1LastState03 == false) {
MIDI_TX(128,sensornote03,127);
Key1LastState03 = true;
else if (sensorValue03 < threshold && Key1LastState03 == true) {
MIDI_TX(144,sensornote03,127);
//SENSOR 04---------------------------------------------------
if (sensorValue04 > threshold && Key1LastState04 == false) {
MIDI_TX(128,sensornote04,127);
Key1LastState04 = true;
else if (sensorValue04 < threshold && Key1LastState04 == true) {
MIDI_TX(144,sensornote04,127);
//SENSOR 05---------------------------------------------------
if (sensorValue05 > threshold && Key1LastState05 == false) {
MIDI_TX(128,sensornote05,127);
Key1LastState05 = true;
else if (sensorValue05 < threshold && Key1LastState05 == true) {
MIDI_TX(144,sensornote05,127);
//SENSOR 06---------------------------------------------------
if (sensorValue06 > threshold && Key1LastState06 == false) {
MIDI_TX(128,sensornote06,127);
Key1LastState06 = true;
else if (sensorValue06 < threshold && Key1LastState06 == true) {
MIDI_TX(144,sensornote06,127);
//SENSOR 07---------------------------------------------------
if (sensorValue07 > threshold && Key1LastState07 == false) {
MIDI_TX(128,sensornote07,127);
Key1LastState07 = true;
else if (sensorValue07 < threshold && Key1LastState07 == true) {
MIDI_TX(144,sensornote07,127);
//SENSOR 08---------------------------------------------------
if (sensorValue08 > threshold && Key1LastState08 == false) {
MIDI_TX(128,sensornote08,127);
Key1LastState08 = true;
else if (sensorValue08 < threshold && Key1LastState08 == true) {
MIDI_TX(144,sensornote08,127);
//SENSOR 09---------------------------------------------------
if (sensorValue09 > threshold && Key1LastState09 == false) {
MIDI_TX(128,sensornote09,127);
Key1LastState09 = true;
else if (sensorValue09 < threshold && Key1LastState09 == true) {
MIDI_TX(144,sensornote09,127);
//SENSOR 10---------------------------------------------------
if (sensorValue10 > threshold && Key1LastState10 == false) {
MIDI_TX(128,sensornote10,127);
Key1LastState10 = true;
else if (sensorValue10 < threshold && Key1LastState10 == true) {
MIDI_TX(144,sensornote10,127);
//SENSOR 11---------------------------------------------------
if (sensorValue11 > threshold && Key1LastState11 == false) {
MIDI_TX(128,sensornote11,127);
Key1LastState11 = true;
else if (sensorValue11 < threshold && Key1LastState11 == true) {
MIDI_TX(144,sensornote11,127);
//SENSOR 12---------------------------------------------------
if (sensorValue12 > threshold && Key1LastState12 == false) {
MIDI_TX(128,sensornote12,127);
Key1LastState12 = true;
else if (sensorValue12 < threshold && Key1LastState12 == true) {
MIDI_TX(144,sensornote12,127);
//SENSOR 13---------------------------------------------------
if (sensorValue13 > threshold && Key1LastState13 == false) {
MIDI_TX(128,sensornote13,127);
Key1LastState13 = true;
else if (sensorValue13 < threshold && Key1LastState13 == true) {
MIDI_TX(144,sensornote13,127);
//SENSOR 14---------------------------------------------------
if (sensorValue14 > threshold && Key1LastState14 == false) {
MIDI_TX(128,sensornote14,127);
Key1LastState14 = true;
else if (sensorValue14 < threshold && Key1LastState14 == true) {
MIDI_TX(144,sensornote14,127);
//SENSOR 15---------------------------------------------------
if (sensorValue15 > threshold && Key1LastState15 == false) {
MIDI_TX(128,sensornote15,127);
Key1LastState15 = true;
else if (sensorValue15 < threshold && Key1LastState15 == true) {
MIDI_TX(144,sensornote15,127);
//SENSOR 16---------------------------------------------------
if (sensorValue16 > threshold && Key1LastState16 == false) {
MIDI_TX(128,sensornote16,127);
Key1LastState16 = true;
else if (sensorValue16 < threshold && Key1LastState16 == true) {
MIDI_TX(144,sensornote16,127);
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
status = MESSAGE + midichannel;
Serial.write(status);
Serial.write(PITCH);
Serial.write(VELOCITY);
