I am very much a newbie to this so please bear with me.
I am using a Mega2560 board. 24 input lines (momentary low as input is activated, 24 leds to show position activated by momentary switch) The board also controls a single channel servo output plus a DC motor speed controller.
It all works well using Virtronics Simulator for Arduino. The code as written compiles and runs fine on the Mega board, everything works.
The problem I am having is a simple one, I can't work out how to enable the INPUT_PULLUP for pins 5 to 28 (the switches defined as switch_up and switch_down) Using that will save me using 24 external pullup resistors.
PaulPB was very helpful in a previous posting (Controlling LEDS with momentary inputs - LEDs and Multiplexing - Arduino Forum), but I can't get his code for enabling the pullup to work - I'm certain its how I am trying to implement it
Any help would be appreciated.
const byte switch_up[12] = {5,7,9,11,13,15,17,19,21,23,25,27};
const byte switch_down[12] = {6,8,10,12,14,16,18,20,22,24,26,28};
const byte led_up[12] = {30,32,34,36,38,40,42,44,46,48,50,53};
const byte led_down[12] = {29,31,33,35,37,39,41,43,45,47,49,51};
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int servopot0 = A0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
int motorpot1 = A1;
int motorPin = 2;
int potValue = 0;
int motorValue = 0;
myservo.attach(3); // attaches the servo on pin 3 to the servo object
val = analogRead(servopot0); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
potValue = analogRead(motorpot1);
motorValue = map(potValue, 0, 1023, 0, 255);
analogWrite(motorPin, motorValue);
delay(2);
for (byte i = 0; i < 12; i++) {
if (digitalRead(switch_up[i]) == LOW) {
digitalWrite(led_up[i], HIGH);
digitalWrite(led_down[i], LOW);
if (digitalRead(switch_down[i]) == LOW) {
digitalWrite(led_down[i], HIGH);
digitalWrite(led_up[i], LOW);
