24LC04B EEPROM read wrong values
Hello,
i have a 24LC04B mounted in a radio and i need to read the whole memory. Already connected the mC and the EEPROM is found by the EEPROM24 class. I use this library: ArduinoLibs: EEPROM24 Class Reference (rweather.github.io)
This is the sketch:
#include <EEPROM24.h>
#include <I2CMaster.h>
#include <SoftI2C.h>
#define PIN_DATA 25
#define PIN_CLK 26
#define PIN_TRIGGER 27
SoftI2C i2c(PIN_DATA, PIN_CLK);
EEPROM24 eeprom(i2c, EEPROM_24LC04);
  Serial.println("Woke Up");
  pinMode(PIN_TRIGGER, INPUT);
  if (eeprom.available()){
    Serial.println("Hello EEPROM");
    Serial.println("Where are you EEPROM?");
    return;
  Serial.print("Size: ");
  Serial.println(eeprom.size());
  int trigger = digitalRead(PIN_TRIGGER);
  if (trigger == 1){
    Serial.println("Speicherabbild:");
    for(int page = 0; page < 32; page++){
      for(int i = 0; i < 16; i++){
        Serial.print(eeprom.read((unsigned long)(page * 16 + i)), HEX);
        Serial.print(" - ");
      Serial.println("|");
  delay(100);
and here the result:
Woke Up
Hello EEPROM
Speicherabbild:
0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - |
Do you know what may be the problem?
Answer 1) Nothing wrong, the EEPROM contains only zeros. What did you expect?
Answer 2) The read() function is returning an error code, which happens to be zero.
uint8_t EEPROM24::read(unsigned long address)
  if (address >= _size)
     return 0;
  writeAddress(address);
  if (!_bus->startRead(i2cAddress, 1))
     return 0;
  return _bus->read();
Edit the library and change those "return 0;" to values 1 and 2, then see what you get.
Karma++ for code tags and clickable link
  1. Well this is not possible. At least the radio code and serial number need to be stored here. I thought i accidentally erased the memory and check it again, but the radio is still working, so there need to be information on it (including radio frequencies that are stored)
  2. great idea, already tried that. it's _bus-read(); that returns 0. Need to check if there are any error codes, too
