Hello.
I am trying to get this code I have to work that I am writing in C. I am trying to get this record and playback working. But for some when I record more than about 665 bytes, the playback no longer works. But any smaller than it works just fine.
If you need more provided please let me know.
void recordSnapshots(uint32_t currentMillis) {
if (currentMillis - lastSnapshotTime >= SNAPSHOT_INTERVAL) {
struct Snapshot snapshot;
snapshot.time = currentMillis - recordingStartTime;
snapshot.buttonStates = 0;
// Capture button states
if (!(PIND & (1 << Button1_Pin))) snapshot.buttonStates |= (1 << 0);
if (!(PIND & (1 << Button2_Pin))) snapshot.buttonStates |= (1 << 1);
if (!(PIND & (1 << Button3_Pin))) snapshot.buttonStates |= (1 << 2);
if (!(PIND & (1 << Button4_Pin))) snapshot.buttonStates |= (1 << 3);
// Calculate address and manage bank switching
uint32_t address = eventCount * sizeof(struct Snapshot) + 2;
if (address >= 0x8000) { // If Bank 1 is full, move to Bank 2
address = (address - 0x8000) + 0x8000;
// Check if EEPROM capacity is exceeded
if (address + sizeof(struct Snapshot) > EEPROM_SIZE) {
PORTB |= (1 << Recording_LED_Pin) | (1 << Playback_LED_Pin); // Indicate error
stopRecording();
return;
// Save the snapshot to EEPROM
saveSnapshotToEEPROM(address, &snapshot);
eventCount++;
lastSnapshotTime = currentMillis;
//Playback snapshots function.
void playBackSnapshots(void) {
uint32_t playbackStartTime = millis();
PORTB |= (1 << Recording_LED_Pin);
for (uint32_t i = 0; i < eventCount; i++) {
uint32_t address = i * sizeof(struct Snapshot) + 2;
if (address >= 0x8000) { // Adjust address for Bank 2
loadSnapshotFromEEPROM(address, &snapshot);
while (millis() - playbackStartTime < snapshot.time) {}
PORTB = (PORTB & ~((1 << LED1_Pin) | (1 << LED2_Pin) | (1 << LED3_Pin) | (1 << LED4_Pin))) |
((snapshot.buttonStates & (1 << 0)) ? (1 << LED1_Pin) : 0) |
((snapshot.buttonStates & (1 << 1)) ? (1 << LED2_Pin) : 0) |
((snapshot.buttonStates & (1 << 2)) ? (1 << LED3_Pin) : 0) |
((snapshot.buttonStates & (1 << 3)) ? (1 << LED4_Pin) : 0);
PORTB &= ~((1 << LED1_Pin) | (1 << LED2_Pin) | (1 << LED3_Pin) | (1 << LED4_Pin));
PORTB &= ~(1 << Recording_LED_Pin);
