#define BT {B11111000,B00100000,B00100000,B00100000,B00100000,B00100000}
#define BU {B10001000,B10001000,B10001000,B10001000,B10001000,B01110000}
#define BM {B10001000,B11011000,B10101000,B10101000,B10001000,B10001000}
#define BE {B11111000,B10000000,B10000000,B11110000,B10000000,B11111000}
#define BH {B10001000,B10001000,B11111000,B10001000,B10001000,B10001000}
#define BI {B11111000,B00100000,B00100000,B00100000,B00100000,B11111000}
#define BS {B01110000,B10001000,B01100000,B00010000,B10001000,B01110000}
#define BD {B11110000,B10001000,B10001000,B10001000,B10001000,B11110000}
#define BY {B10001000,B01010000,B00100000,B00100000,B00100000,B00100000}
#define BP {B11110000,B10001000,B10001000,B11110000,B10000000,B10000000}
#define COMA{B00000000,B00000000,B00000000,B00110000,B00110000,B01100000}
#define SPACE{B00000000,B00000000,B00000000,B00000000,B00000000,B00000000}
#define NUM0{B01110000,B10011000,B10101000,B10101000,B11001000,B01110000}
#define NUM1{B00100000,B01100000,B10100000,B00100000,B00100000,B01110000}
#define NUM2{B01110000,B10001000,B00001000,B01110000,B10000000,B11111000}
#define NUM3{B11110000,B00001000,B00001000,B01111000,B00001000,B11110000}
#define NUM4{B10001000,B10001000,B10001000,B11111000,B00001000,B00001000}
#define NUM5{B11111000,B10000000,B11110000,B00001000,B10001000,B01110000}
#define NUM6{B11111000,B10000000,B11111000,B10001000,B10001000,B11111000}
#define NUM7{B11111000,B00001000,B00001000,B01111000,B00001000,B00001000}
#define NUM8{B11111000,B10001000,B11111000,B10001000,B10001000,B11111000}
#define NUM9{B11111000,B10001000,B11111000,B00001000,B00001000,B11111000}
byte humidityArray [12][6]= {BH,BU,BM,BI,BD,BI,BT,BY,SPACE,BI,BS,SPACE};
byte tempArray[8][6] = {BT,BE,BM,BP,SPACE,BI,BS};/*old array looked like {BT,BE,BM,BP,SPACE,BI,BS,SPACE}*/
byte numArray [10][6]={NUM0,NUM1,NUM2,NUM3,NUM4,NUM5,NUM6,NUM7,NUM8,NUM9};
byte newArray[100][6];
int key = 0;
int latchPin = 10;
int clockPin = 13;
int dataPin = 11;
int clock = 9;
int Reset = 8;
int latchPinPORTB = latchPin - 8;
int clockPinPORTB = clockPin - 8;
int dataPinPORTB = dataPin - 8;
int i = 0;
long scrolling_word[6];
int array_turn = 0;
int delay_langth;
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(Reset, OUTPUT);
digitalWrite(Reset, HIGH);
digitalWrite(Reset, LOW);
setupSPI();
void display_word(int loops,byte word_print[][6],int num_patterns,int delay_langth){// this function displays your symbols
i = 0;// resets the counter fot the 4017
for(int b=0;b<10;b++)
for(int n=0;n<8;n++)
Serial.print(word_print[b][n]);
Serial.print("||");
for(int g=0;g<6;g++)//resets the the long int where your word goes
scrolling_word[g] = 0;
for(int x=0;x<num_patterns;x++)
{//main loop, goes over your symbols
for(int r=0;r<6;r++)//puts the buildes the first symbol
scrolling_word[r] |= word_print[x][r];
for (int z=0;z<6;z++)
{//the sctolling action
for(int p=0;p<6;p++)
scrolling_word[p] = scrolling_word[p] << 1;
// end of the scrolling funcion
for(int t=0;t<delay_langth;t++)
{// delay function for slower image increas delay_langth
for(int y=0;y<6;y++){// scaning the display
if(i == 6)
{ // counting up to 6 with the 4017
digitalWrite(Reset,HIGH);
digitalWrite(Reset,LOW);
i = 0;
latchOff();
spi_transfer(make_word(0x01000000,y));// sending the data
spi_transfer(make_word(0x00010000,y));
spi_transfer(make_word(0x00000100,y));
latchOn();
delayMicroseconds(800);//waiting a bit
latchOff();
spi_transfer(0);// clearing the data
spi_transfer(0);
spi_transfer(0);
latchOn();
digitalWrite(clock,HIGH);//counting up with the 4017
digitalWrite(clock,LOW);
i++;
finish_scroll(delay_langth);// zabavq bqgashtiq teks pri uveli4avane !!!!
void finish_scroll(int delay_scroll){// this function is the same as the funcion above, it just finishing scrolling
for (int n=0;n<24;n++){
for(int h=0;h<6;h++)
scrolling_word[h] = scrolling_word[h] << 1;
for(int w=0;w<delay_scroll;w++){
for(int k=0;k<6;k++){
if(i == 6){
i = 0;
latchOff();
spi_transfer(make_word(0x01000000,k));
spi_transfer(make_word(0x00010000,k));
spi_transfer(make_word(0x00000100,k));
latchOn();
latchOff();
spi_transfer(0);
spi_transfer(0);
spi_transfer(0);
latchOn();
i++;
byte make_word (long posistion,byte turn)
byte dummy_word = 0;
for(int q=0;q<8;q++)
if(scrolling_word[turn] & (posistion<<q))
dummy_word |= 0x01<<q;
return dummy_word;
int tempVal= 12;
int firstNum=tempVal/10;
int secondNum= tempVal%10;
float num=45.8;
int numInt;
numInt=int(num);
Serial.print("numInt is:");
Serial.println(numInt);*/
for(int a=0;a<10;a++)
switch (a)
case 0:
for(int b=0;b<6;b++)
newArray[a][b]=tempArray[a][b];
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
newArray[a][b]=numArray[firstNum][b];
case 9:
newArray[a][b]=numArray[secondNum][b];
array_turn=10;
display_word(1,newArray, array_turn, 32 );
void latchOn(){
bitSet(PORTB,latchPinPORTB);
void latchOff(){
bitClear(PORTB,latchPinPORTB);
void setupSPI(){
byte clr;
SPCR |= ( (1<<SPE) | (1<<MSTR) ); // enable SPI as master
//SPCR |= ( (1<<SPR1) | (1<<SPR0) ); // set prescaler bits
SPCR &= ~( (1<<SPR1) | (1<<SPR0) ); // clear prescaler bits
clr=SPSR; // clear SPI status reg
clr=SPDR; // clear SPI data reg
SPSR |= (1<<SPI2X); // set prescaler bits
//SPSR &= ~(1<<SPI2X); // clear prescaler bits
delay(10);
byte spi_transfer(byte data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait the end of the transmission
return SPDR; // return the received byte, we don't need that
I solved my problem, but i don’t understand why it happens.
When i removed “Space” from “tempArray” everything worked fine.
