%2520 spazio inece che %20
Ciao a tutti ho un problema :
dotazione:
nodemcu
sketch:
#include <ESP8266WiFi.h>
const char* ssid     = "rete";
const char* password = "pwd adsl";
const char* host = "dominio.it";
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
int value = 0;
  delay(5000);
  ++value;
  Serial.print("connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    return;
  // We now create a URI for the request ,
  String url = "/track/requests.php?a=upload&u=test2&p=password&lat=000&long=0000&do=2016-10-16";
url += "%20";
url += "18:00:00&tn=nodemcu&db=8&ang=0.0&sp=0.0&alt=10.0";
////url += "";
// url += "";
//String encoded=urlencode(url);
//Serial.println(encoded);
//  String decoded=urldecode(encoded);
//  Serial.println(decoded);
  String decoded=(url);
//String encoded=urlencode("Hello\nWorld");
//  Serial.println(encoded);
  Serial.print("Requesting URL: ");
  Serial.println(url);
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while(client.available()){
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println("closing connection");
nello sketch dopo essermi connesso creo un url e lo passo ad una pagina php.
Tra la data e l' ora url deve avere uno spazio
ma il server restituisce pagina non trovata perchè in corrispondenza di %20 l'url finale è %2520
Con tutti quei commenti non si capisce se usi o meno la funzione urlencode(). Se la usi, essa si occupa di codificare opportunamente i caratteri "strani", per cui non devi aggiungere %20 alla stringa, ma un vero e proprio spazio.
ciao allora
1)se non la uso, e metto %20 (al posto dello spazio) l url generato è....%2520... e in print la pagina ovviamente non viene trovata
2) se non la uso e metto spazio la url viene troncata prima dello spazio
3)se la uso metto spazio la url viene troncata prima dello spazio
HELPPP
Secondo me hai fatto casino da qualche parte, la soluzione giusta è: metti uno spazio normale nella stringa e chiamaci urlencode() sopra. Riprova così e poi posta lo sketch corretto, se ancora non funziona.
allora questo il codice:
const char* ssid     = "adsl";
const char* password = "pwd";
String urldecode(String str)
    String encodedString="";
    char c;
    char code0;
    char code1;
    for (int i =0; i < str.length(); i++){
        c=str.charAt(i);
      if (c == '+'){
        encodedString+=' ';
      }else if (c == '%') {
        i++;
        code0=str.charAt(i);
        i++;
        code1=str.charAt(i);
        c = (h2int(code0) << 4) | h2int(code1);
        encodedString+=c;
      } else{
        encodedString+=c;
      yield();
   return encodedString;
String urlencode(String str)
    char c;
    char code0;
    char code1;
    char code2;
      c=str.charAt(i);
      if (c == ' '){
        encodedString+= '+';
      } else if (isalnum(c)){
        encodedString+=c;
      } else{
        code1=(c & 0xf)+'0';
        if ((c & 0xf) >9){
            code1=(c & 0xf) - 10 + 'A';
        c=(c>>4)&0xf;
        code0=c+'0';
        if (c > 9){
            code0=c - 10 + 'A';
        code2='\0';
        encodedString+='%';
        encodedString+=code0;
        encodedString+=code1;
        //encodedString+=code2;
      yield();
unsigned char h2int(char c)
    if (c >= '0' && c <='9'){
        return((unsigned char)c - '0');
    if (c >= 'a' && c <='f'){
        return((unsigned char)c - 'a' + 10);
    if (c >= 'A' && c <='F'){
        return((unsigned char)c - 'A' + 10);
    return(0);
  delay(10);
    Serial.print(".");
  Serial.println("");
int value = 0;
  delay(5000);
  ++value;
  WiFiClient client;
    return;
  String url = "/track/requests.php?a=upload&u=test2&p=pwd&lat=000&long=000&do=2016-10-16 18:00:00&tn=nodemcu&db=8&ang=0.0&sp=0.0&alt=10.0";
Serial.print("stringa decoded ");
String urlencode=(url);
  Serial.println(urlencode);
  client.print(String("GET ") + urlencode + " HTTP/1.1\r\n" +
      client.stop();
      return;
    Serial.print(line);
questa la seriale:
Connecting to adsl
WiFi connected
IP address:
192.168.0.100
connecting to dominio.it
stringa decoded /track/requests.php?a=upload&u=test2&p=pwd&lat=000&long=000&do=2016-10-16 18:00:00&tn=nodemcu&db=8&ang=0.0&sp=0.0&alt=10.0
HTTP/1.1 301 Moved Permanently
Date: Wed, 19 Oct 2016 14:03:36 GMT
Server: Apache
Location: http://www.dominio.it/track/requests.php?a=upload&u=test2&p=pwd&lat=000&long=000&do=2016-10-16
Content-Length: 345
Connection: close
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="http://www.dominio.it/track/requests.php?a=upload&amp;u=test2&amp;p=pwd&amp;lat=000&amp;long=000&amp;do=2016-10-16">here</a>.</p>
</body></html>
closing connection
quindi come dicevo l url la tronca allo spazio
Solito copia&incolla senza avere idea di quel che stai facendo, vero? Prova questo:
 client.print(String("GET ") + urlencode(url) + " HTTP/1.1\r\n" +
exit status 1
ambiguous overload for 'operator+' (operand types are 'String' and 'String(String)')
Devi cancellare le righe in mezzo...
ops avevo sbagliato ora carica ma comunque non va
ho messoprima un
Serial.println(urlencode(url));
e la seriale stampa:
Connecting to adsl
WiFi connected
IP address:
192.168.0.100
%2Ftrack%2Frequests%2Ephp%3Fa%3Dupload%26u%3Dtest2%26p%3Dpwd%26lat%3D000long%3D000%26do%3D2016%2D10%2D16+18%3A00%3A00%26tn%3Dnodemcu%26db%3D8%26ang%3D0%2E0%26sp%3D0%2E0%26alt%3D10%2E0
HTTP/1.1 400 Bad Request
Date: Wed, 19 Oct 2016 14:38:28 GMT
Server: Apache
Content-Length: 226
Connection: close
<html><head>
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.
</p>
</body></html>
closing connection
copio & incollo a volte non passo dal libretto delle istruzioni mi ci butto di testa e molte volte mi fermo poi ci ritorno ma non mollo :wink:
Ho capito, fai questo:
String url = "/track/requests.php?a=upload&u=test2&p=pwd&lat=000&long=000&do=" + urlencode ("2016-10-16 18:00:00") + "&tn=nodemcu&db=8&ang=0.0&sp=0.0&alt=10.0";
anche cosi converte i : e - allora ho fatto cosi
String url = "/track/requests.php?a=upload&u=test2&p=pwd&lat=000&long=000&do=2016-10-16" + urlencode (" ") + "18:00:00&tn=nodemcu&db=8&ang=0.0&sp=0.0&alt=10.0";
ma la seriale stampa
....&amp;do=2016-10-16+18:00:00&a.....
Ma è giusto che converta i : e i -, non ti preoccupare, verranno opportunamente decodificati "dall'altra parte". Inoltre gli spazi possono essere convertiti in +, è come %20, non ti preoccupare neanche di questo.
Date: Wed, 19 Oct 2016 15:46:14 GMT
Server: Apache
Location: http://www.dominio.it/track/requests.php?a=upload&u=test2&p=pwd&lat=000&long=000&do=2016%252D10%252D16+18%253A00%253A00&tn=nodemcu&db=8&ang=0.0&sp=0.0&alt=10.0
Content-Length: 419
Connection: close
<html><head>
</head><body>
<p>The document has moved <a href="http://www.dominio.it/track/requests.php?a=upload&amp;u=test2&amp;p=pwd&amp;lat=000&amp;long=000&amp;do=2016%252D10%252D16+18%253A00%253A00&amp;tn=nodemcu&amp;db=8&amp;ang=0.0&amp;sp=0.0&amp;alt=10.0">here</a>.</p>
</body></html>
closing connection
Beh, secondo me è giusto. Hai verificato bene cosa c'è di diverso nell'indirizzo che ti propone? Hai provato a copiare l'URL e incollarlo in un browser?
Be che dirti hai ragione....
allora l' url generata se la incollo nel browser funziona e la pagina php passa i valori nel db...
ma url se invece la passa nodemcu crea dei caratteri "&" al posto "&" e quindi la pagina non viene trovata sul server
Date: Thu, 20 Oct 2016 06:04:44 GMT
Server: Apache
Content-Length: 419
Connection: close
<html><head>
</head><body>
</body></html>
closing connection
bisognerebbe fare un urlencode solo per &?
No, quello è il server che ti risponde e deve per forza trasformare le & in &, perché non si può scrivere & da solo in HTML. Sei sicuro che il problema non sia nella prima parte dell'URL? Quando lo apri nel browser ti ridireziona da qualche parte?
tarata:
ciao allora
HELPPP
%25 è la codifica del % in esadecimale. Mi sa che c'è un urlencode nascosto.
Quindi io proverei senza urlencode e con lo spazio al posto del %20. Solo che verrebbe troncata prima dello spazio. E allora prova on i caratteri d'escape dovrebbe essere "\ ", senza le virgolette.
È quello che abbiamo già fatto :).
Allora...la cosa sembra piu difficile di quanto pensavo:
digitando la stringa url
la pagina php che si occupa di gestire l' url mi da: Result:5
Qui posto il codice della pagina requests.php che da quest' errore :
<?php
    define("R_OK", 0);
    require_once("database.php");
    function run($connection)
  $requireddb = urldecode($_GET["db"]);
  if ( $requireddb == "" || $requireddb < 8 )
            return "Result:5";
        $db = connect_save($connection);
        if (is_null($db))
            return "Result:4";
	// Check username and password
        $username = $_GET["u"];
        $password = $_GET["p"];
	// User not specified
	if ( $username == "" || $password == "" )
            return "Result:3";
        $userid = $db->valid_login($username, $password);
        switch ($userid) {
        case NO_USER:
            $userid = $db->create_login($username, $password);
            if ($userid < 0)
                return result(2);
        case INVALID_CREDENTIALS:
            return result(1);  // user exists, password incorrect.
        case LOCKED_USER:
            return "User disabled. Please contact system administrator";
	$tripname = urldecode($_GET["tn"]);
	$action = $_GET["a"];
	if ($action=="noop")
            return "Result:0";
Ma nell'url non devi mettere &amp!
Ascolta, forse è meglio che investi un attimo a capire quali caratteri si possono usare negli URL e nell'html e quali metodi si usano per ovviare alle limitazioni nei due casi. Andando a caso non arriverai da nessuna parte.
