25Khz PWM Pin 3 ,Pin 9
Hi, I need help.. how to generate 25Khz PWM for Pin 3/9 , what is the code? Thanks
Which Arduino?
Sorry. . Arduino Uno and Arduino Mega
Here's a way to do it on an Uno. The Mega is similar except that pin 3 uses the OC3C output of TIMER3 and pin 9 uses the OC2B output of TIMER2.
const uint8_t pinNine = 9;  //PB1, OC1A
const uint8_t pinThree = 3; //PD3, OC2B
void setup( void )
    //set up pin 9 output
    //  TIMER1 16-bit
    //      /1 prescaler CLK = 16MHz T=62.5nS
    //      ICR1 = ((1/25000) / 62.5nS) - 1 = 639
    //      OCR1A = (ICR1+1)/2 = 320
    //      WGM14; ICR1 sets TOP
    //      OC sets on bottom, clears on compare
    TCCR1A = _BV(COM1A1) | _BV(WGM11);
    TCCR1B = _BV(WGM13) | _BV(WGM12) | _BV(CS10);
    ICR1 = 639;
    OCR1A = 320;
    pinMode( pinNine, OUTPUT );
    //  TIMER2 8-bit
    //      /8 prescaler; CLK = 2MHz T=500nS
    //      OCR2A = ((1/25000) / 500nS) - 1 = 79
    //      OCR2B = (OCR2A+1)/2 = 40
    //      WGM7; OCR2A sets TOP
    TCCR2A = _BV(COM2B1) | _BV(WGM21) | _BV(WGM20);
    TCCR2B = _BV(WGM22) | _BV(CS21);
    OCR2A = 79;
    OCR2B = 40;
    pinMode( pinThree, OUTPUT );
}//setup
void loop( void )
}//loop
