I am using a 28BYJ-48 5V stepper motor with a ULN2003 driver. They are connected to an external power supply. We are tasked with using this setup as a "motor" for our RC car. The current draw at "full" is around 220mA. I am a little new to programming and am having a hard time understanding the different functions of the AccelStepper library. Are these the maximum settings? Thank you for your time.
#include <IRremote.hpp>
#include <LedControl.h>
#include <AccelStepper.h>
#define IR_RECEIVE_PIN A1
#define HALFSTEP 4
void printByte(byte character[]);
int DIN = 12;
int CS = 11;
int CLK = 10;
LedControl lc=LedControl(DIN,CLK,CS,0);
byte forward_left[8]= {0x1F,0x1F,0x18,0x18,0xDB,0x7E,0x3C,0x18};
byte forward[8]= {0x10,0x30,0x60,0xFF,0xFF,0x60,0x30,0x10,};
byte forward_right[8]= {0x18,0x3C,0x7E,0xDB,0x18,0x18,0x1F,0x1F};
byte rotate_counter_clockwise[8]= {0x2E,0x4C,0x8A,0x81,0x81,0x51,0x32,0x74,};
byte smiley_face[8]= {0x08,0x64,0x62,0x02,0x02,0x62,0x64,0x08};
byte rotate_clockwise[8]= {0x74,0x32,0x51,0x81,0x81,0x8A,0x4C,0x2E,};
byte reverse_left[8]= {0xF8,0xF8,0x18,0x18,0xDB,0x7E,0x3C,0x18};
byte reverse[8]= {0x08,0x0C,0x06,0xFF,0xFF,0x06,0x0C,0x08,};
byte reverse_right[8]= {0x18,0x3C,0x7E,0xDB,0x18,0x18,0xF8,0xF8};
byte display_initial[8]= {0x18,0x3C,0x7E,0xDB,0x18,0x18,0xF8,0xF8};
AccelStepper left_stepper(HALFSTEP, 9, 7, 8, 6);
AccelStepper right_stepper(HALFSTEP, 5, 3, 4, 2);
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
lc.shutdown(0,false);
lc.setIntensity(0,0);
lc.clearDisplay(0);
left_stepper.setMaxSpeed(1000);
left_stepper.setAcceleration(200);
right_stepper.setMaxSpeed(1000);
right_stepper.setAcceleration(200);
if (IrReceiver.decode()) {
switch (IrReceiver.decodedIRData.decodedRawData) {
case 0xE619FF00: // 0
Serial.println("Pressed: 0 - Display Initial");
printByte(display_initial);
left_stepper.setSpeed(0);
right_stepper.setSpeed(0);
case 0xBA45FF00: // 1
Serial.println("Pressed: 1 - Forward Left");
printByte(forward_left);
left_stepper.setSpeed(250); // slower left
right_stepper.setSpeed(500); // faster right
case 0xB946FF00: // 2
Serial.println("Pressed: 2 - Forward");
printByte(forward);
left_stepper.setSpeed(500); // forward
right_stepper.setSpeed(500); // forward
case 0xB847FF00: // 3
Serial.println("Pressed: 3 - Forward Right");
printByte(forward_right);
left_stepper.setSpeed(500); // faster left
right_stepper.setSpeed(250); // slower right
case 0xBB44FF00: // 4
Serial.println("Pressed: 4 - Rotate Counter Clockwise");
printByte(rotate_counter_clockwise);
left_stepper.setSpeed(-500); // backward left
right_stepper.setSpeed(500); // forward right
case 0xBF40FF00: // 5
Serial.println("Pressed: 5 - Smiley Face");
printByte(smiley_face);
case 0xBC43FF00: // 6
Serial.println("Pressed: 6 - Rotate Clockwise");
printByte(rotate_clockwise);
left_stepper.setSpeed(500); // forward left
right_stepper.setSpeed(-500); // backward right
case 0xF807FF00: // 7
Serial.println("Pressed: 7 - Reverse Left");
printByte(reverse_left);
left_stepper.setSpeed(-250); // slower backward left
right_stepper.setSpeed(-500); // faster backward right
case 0xEA15FF00: // 8
Serial.println("Pressed: 8 - Reverse");
printByte(reverse);
case 0xF609FF00: // 9
Serial.println("Pressed: 9 - Reverse Right");
printByte(reverse_right);
left_stepper.setSpeed(-500); // faster backward left
right_stepper.setSpeed(-250); // slower backward right
default:
IrReceiver.resume();
left_stepper.runSpeed();
right_stepper.runSpeed();
void printByte(byte character []) {
int i = 0;
for(i=0;i<8;i++) {
lc.setRow(0,i,character[i]);
