Hi everyone, I have an Arduino Uno connected with my stepper motor 28BYJ-48, with 5V.
The code runs okay, but, if I take stepsPerRevolution to 400, or over it the motor just shake, but do not turn the engine on the top. I can not see any movement at all, and I do not know why, even after I ran the code a lot of time. Can someone explain it? Because the datasheet says that I can use it until 4096 steps, so now I am confused. What is the max steps that the motor 28BYJ-48 can run on real?
code link: #include <Stepper.h> const int stepsPerRevolution = 300; //<400 Stepper m - Pastebin.com
datasheet: http://robocraft.ru/files/datasheet/28BYJ-48.pdf
Steps per revolution is not a variable. It is the physical number of steps that the stepper motor need to rotate through 360°. For a 28BYJ-48 the output shaft turns once for every 2048 steps.
You can use half-stepping so that it need 4096 steps for 1 rotation.
Neither of these numbers has anything to do with the speed of the motor. The speed (which I think is what you are referring to) is determined by the number of steps per second or per minute.
If you want more help please post your program here using the code button </>
…R
