28BYJ-48 & Soft WDT Reset
I'm trying to run stepper CW then CCW but it resets before CCW command.
I've read esp8266 needs to call wifi a lot, but I don't understand how that affects this.
Error message below
⸮clockwise
Soft WDT reset
stack>>>
ctx: cont
sp: 3ffffde0 end: 3fffffc0 offset: 01b0
3fffff90: 3fffdad0 3ffee270 3ffee228 40201073
3fffffa0: feefeffe 00000000 3ffee298 40201c04
3fffffb0: feefeffe feefeffe 3ffe84f4 401004e9
<<<stack<<<
#include <Stepper.h>
// Define number of steps per rotation:
const int stepsPerRevolution = 2048;
// Wiring:
// Pin 8 16 to IN1 on the ULN2003 driver
// Pin 9 5  to IN2 on the ULN2003 driver
// Pin 10 4  to IN3 on the ULN2003 driver
// Pin 11 0   to IN4 on the ULN2003 driver
// Create stepper object called 'myStepper', note the pin order:
Stepper myStepper = Stepper(stepsPerRevolution, 16, 4, 5, 0);
// Set the speed to 5 rpm:
myStepper.setSpeed(10);
// Begin Serial communication at a baud rate of 9600:
  // Step one revolution in one direction:
  Serial.println("clockwise");
  myStepper.step(stepsPerRevolution);
  // Step one revolution in the other direction:
  Serial.println("counterclockwise");
  myStepper.step(-stepsPerRevolution);
What power supply are you using to power the UL2003 module?
I just read library stepper.h
Stepper - step()
This function turns the motor a specific number of steps, at a speed determined by the most recent call to setSpeed(). This function is blocking; that is, it will wait until the motor has finished moving to pass control to the next line in your sketch. For example, if you set the speed to, say, 1 RPM and called step(100) on a 100-step motor, this function would take a full minute to run. For better control, keep the speed high and only go a few steps with each call to step().
Syntax
step(steps)
Parameters
  • steps: the number of steps to turn the motor. Positive integer to turn one direction, negative integer to turn the other.
